Thread: Run dual Bose amps
Results 1 to 5 of 5
  1. #1 Run dual Bose amps
    Jun 2016
    Georgia
    I want to run dual Bose amps. The stock amp for the stock subs & then a 2nd Bose for two 6x9s. Has any one done this? Can any one point me in the right direction
  2. #2 Re: Run dual Bose amps
    Nov 2015
    WI
    My guess is the time it would take to install a second amp would be the same as a small aftermarket one and the aftermarket one would have 2 to 3 times the output.
    Is there a reason you want to run a second bose amp over aftermarket?
  3. #3 Re: Run dual Bose amps
    Jun 2016
    Georgia
    They just always sound so much clearer than other amps
  4. #4 Re: Run dual Bose amps
    Antioch, IL
    Buy actual quality items and you will eat what you just said.
    My last car I threw the bose amp out and wired in a $120 aftermarket amp, it **** all over the bose.
    2009 Challenger SRT8
    Expert at being gay.
  5. #5 Re: Run dual Bose amps
    Quote Originally Posted by ItHurtz View Post
    And ^^^^ is a hack according to Scott... so that's saying a lot about the amp. Personally I did an aftermarket 5 channel and don't think a factory setup on any W body is worthy.
  1. Grounding both amps?
    By Magnaflow GP in forum Audio, Security & Visual Electronics
    Last Post: 03-08-2010, 03:52 PM
  2. Does Bose Work with Non-Bose cars?
    By grandprix17 in forum Audio, Security & Visual Electronics
    Last Post: 02-14-2010, 08:07 AM
  3. Amps?
    By gpgt in forum Audio, Security & Visual Electronics
    Last Post: 03-28-2009, 12:01 PM
