Thread: Steer Control Harness
Results 1 to 8 of 8
  1. #1 Steer Control Harness
    Apr 2016
    Hollywood, Fl
    Im looking for a wire harness without onstar to install my aftermarket radio to keep the steer wheel control but I will install the radio without it.
  2. #2 Re: Steer Control Harness
    From what year dust though automobile hail? I am assuming 97-03?
    This one if your radio has a remote input http://www.pac-audio.com/productDeta...&CategoryID=29
    This one if it does not http://www.pac-audio.com/productDeta...&CategoryID=29
  3. #3 Re: Steer Control Harness
    Apr 2016
    Hollywood, Fl
    It for a 2006 Pontiac Grand Prix base model without on star
  4. #4 Re: Steer Control Harness
    Either of those should work, just get the one that works with your aftermarket head unit.
    Idk if you have searched but this was the first harness adapter I found that says it works with a 2006 base, http://www.amazon.com/Metra-LC-GMRC-.../dp/B001XOBU4C you will still need the antenea adapter and the steering wheel control adapter.
  5. #5 Re: Steer Control Harness
    GTP Level Member simbah's Avatar
    Lala land
    http://www.metraonline.com/part/GMOS-01
    http://www.pac-audio.com/productDeta...?ProductId=207
    This is what I used in my 06 Grand Prix and had no problems.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  6. #6 Re: Steer Control Harness
    Quote Originally Posted by simbah View Post
    From the sounds of things he has a base model gp, so no bells and whistles, so he has no need for the GMOS-01.
  7. #7 Re: Steer Control Harness
    Apr 2016
    Hollywood, Fl
    Well thanks you guys. I was looking to install neon headlight in my car. Is that a good idea or no?
  8. #8 Re: Steer Control Harness
    Quote Originally Posted by TrellBabii View Post
    Neon headlight?
  1. WTB: Ignition Control Harness
    By Jomamma in forum Wanted To Buy - Parts
    Last Post: 09-14-2015, 10:04 AM
  2. wont steer
    By 94grandprix in forum Brakes/Suspension/Chassis
    Last Post: 08-05-2012, 07:11 PM
  3. steering wheel control harness
    By Stragler in forum Audio, Security & Visual Electronics
    Last Post: 05-26-2011, 02:34 PM
  4. noise when i steer
    By mezzoni in forum General Tech Discussion
    Last Post: 03-24-2010, 10:29 PM
  5. Torque Steer?
    By jdkhunter in forum Brakes/Suspension/Chassis
    Last Post: 04-08-2009, 04:07 PM
