Thread: Key FOB Malfunctioning?
Results 1 to 9 of 9
  1. #1 Key FOB Malfunctioning?
    Mar 2016
    Pittsburgh
    I just bought an '06 GP, and I'm having some issues with the remote key fobs.
    I've replaced the battery in one of them, and supposedly the previous owner replaced the battery in the other one.
    However, they hardly ever work. I have to be right next to the car, and even then I'll have to push the unlock button 7 or 8 times before it works.
    I've taken it apart, cleaned it with DEOXIT, and still have problems.
    Has anyone else had similar issues, and if so what did you do?
    thanks
  2. #2 Re: Key FOB Malfunctioning?
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Maybe the contacts under the buttons are worn. Try putting little pieces of foil between the buttons and circuit board to help with conductivity.
  3. #3 Re: Key FOB Malfunctioning?
    SWPA
    Two things happen. Like said the buttons wear out. Auto parts stores sell just the case now and it comes with a case and buttons and you just put your circuit board inside.
    The other thing that happens is the battery holder becomes partially desoldered from the board.
  4. #4 Re: Key FOB Malfunctioning?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    You can buy replacement fobs on amazon for around $15 a pop, not sure if 04+ GP's allow user programming of fobs without a special tool though.
    I'd just buy new fobs personally....
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  5. #5 Re: Key FOB Malfunctioning?
    SWPA
    04+ require Tech2
  6. #6 Re: Key FOB Malfunctioning?
    Knoxville, TN
    04+ require Tech2
    Ah, shame. Seems silly, when older models have a simple programming procedure through the factory radio.
  7. #7 Re: Key FOB Malfunctioning?
    Yoga city
    Yes these are prone to the connections being broken due to crap solder. than like other have said check the pads, you can get a replacement case and still use your "guts" so you don't have to reprogram. As long as the contacts board side are in good shape you may just need the pad connections.
  8. #8 Re: Key FOB Malfunctioning?
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Also at the parts store they may have a device to test your remote. I have a similar problem with my 97, however I can confirm it isn't the remote. I can get the tester to light up green from a very acceptable distance.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  9. #9 Re: Key FOB Malfunctioning?
    Yoga city
    May be the same issue I had originally, my receiver in my car was shot. it would loose my learn each time.
  1. Instrument cluster malfunctioning?
    By Joshmoshh in forum Audio, Security & Visual Electronics
    Last Post: 05-22-2012, 08:17 AM
  2. Gas gauge Malfunctioning/Floating .....
    By moddman in forum General Tech Discussion
    Last Post: 02-21-2012, 06:31 AM
  3. Malfunctioning Steering Wheel Interface?
    By SliceTheRice in forum Audio, Security & Visual Electronics
    Last Post: 08-12-2010, 02:05 PM
  4. DIC Display and A/C Malfunctioning
    By GPGT40 in forum General Tech Discussion
    Last Post: 01-16-2010, 03:24 PM
  5. DIC Display and A/C Malfunctioning
    By GPGT40 in forum Audio, Security & Visual Electronics
    Last Post: 01-16-2010, 01:31 PM
