Thread: Stock radio questions
Results 1 to 11 of 11
  1. #1 Stock radio questions
    Sep 2015
    Michigan
    On the back of the radio I have to plugs. The one is for speakers, power, ect. The second one is smaller I assume this is for the factory amp. We plugged in the aftermarket radio and have power and every thing works but no sound. The wire harness we got didn't have any second plug for or any thing for that second plug. Did I get the wrong adapter? I'm just learning.
  2. #2 Re: Stock radio questions
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    You have to go to like walmart and look up the year and model of your car on the back of the wire harness boxes. Then hook those wires to your wires coming out of your aftermarket radio then that plug you get from like walmart will plug right into your factory radio plug on the car.
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  3. #3 Re: Stock radio questions
    SE Level Member MrDavid's Avatar
    Jan 2016
    Sault Ste. Marie, ON
    Which stock radio did you have? What year of car? I changed my radio the other day. My car is a 2005 base and it had 2 plugs. The smaller one is no longer in use and has 4 wires. My car does not have an amp. Hopefully that'll help you identify yours.
  4. #4 Re: Stock radio questions
    Jul 2015
    Jamestown, NY
    2000 but they are all pretty much the same I've done them on 04+ grand prixs to
  5. #5 Re: Stock radio questions
    Jan 2016
    reason I'm asking is to help identify whether or not he has the monsoon/bose system
  6. #6 Re: Stock radio questions
    Jul 2015
    Jamestown, NY
    Oh I don't have the bose system I've replaced them with better speakers our cars are old lol
  7. #7 Re: Stock radio questions
    Sep 2015
    Michigan
    Sorry about that. Standard radio no steering wheel controls. Just wated to know what the smaller plug was for. I get power to the radio just no sound. Was wondering if that small plug had something to do with that.
  8. #8 Re: Stock radio questions
    Jul 2015
    Jamestown, NY
    Is there anyway you can post pictures of what you have going on?
  9. #9 Re: Stock radio questions
    Feb 2016
    Marathon
    Has anyone ever had all the bass go away and just have treble ? its like my factory amp went into protection mode or something.
  10. #10 Re: Stock radio questions
    Donating Users moddman's Avatar
    Midwest
    3.4" ZZP MPS Pull
    ey,ZZP Coupler,NGK PLUGS,L67 Coils,INTENSE 1.8 RR, Custom PCM Tune, ZZP Stage 2 IC, 180* T-Stat, 42LB RE-FLWD Inj.
  11. #11 Re: Stock radio questions
    GT Level Member mguzzo's Avatar
    Buffalo NY
    on a standard stock radio there are three connectors, C1 is the speakers L and R front, ground, power, and dimmer. C2 is steering wheel controls, serial data for HUD, and speaker L and R rear. C1 and C2 are stacked so they appear as one connector. C3 is an 9 pin flat connector, only 3 pins are used for remote CD audio.
    so for an aftermarket harness you need to connect it to match up properly. the smaller connector you don't need.
    Here's the wiring
    C1
    1 gray LF -
    2 tan LF +
    3 dk grn RF -
    4 lt grn RF +
    5 blk/wht ground
    6 gry/blk lights
    7 brn/wht dimmer
    8 dk grn radio On output (e.g for powered antenna)
    9 yel fused acc power (RAP)
    10 orn +12V fused
    C2
    11 blank
    12 blank
    13 blank
    14 dk blu steering wheel inputs
    15 dr grn HUD serial data
    16 blank
    17 lt blu RR -
    18 dk blu RR +
    19 yel LR -
    20 brn LR +
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  1. xm radio questions
    By chiana4477 in forum Off Topic Discussion
    Last Post: 11-08-2010, 05:15 PM
  2. Questions about the Radio/CD Player - Not Working
    By sb76 in forum General Tech Discussion
    Last Post: 03-03-2010, 10:25 AM
  3. technical questions about stock radio
    By MrTube in forum Audio, Security & Visual Electronics
    Last Post: 01-16-2010, 08:12 PM
