Quote Originally Posted by nox View Post
The hard part on the fronts is the door panels. I'd advise getting extra pins as they break ridiculously easily when pulling the panel. With tweeters the hard part will be feeding the wires through the door, string and a weight of some kind will be your friend.
As for the rears, be careful with the pull tabs on the bottom of the bench seat as they like to break off. When replacing the rear shelf be extremely careful as it like to fold under the shroud for the breaklight instead of into the groove.
Sent from my ASUS_Z00TD using Tapatalk
thanks man. I've had the rears out before and the door panels have been off for replacing a switch. But the advice on the tweeters is much appreciated since I've never had them out.
