Thread: New head unit no sound.
Results 1 to 9 of 9
  1. #1 New head unit no sound.
    Jun 2015
    El Paso
    Well i swapped the head unit everything fine and I have no sound at all. I have a 00 with the Bose audio system. I'm assuming it's because I don't have the smaller harness connected. I tried with the old one without as well and no sound either. Is there a proper way of getting this to work without having to buy a harness? Or do I have to wait till after the holidays to do it right? I want the amp to still work correctly with the new unit. Any ideas?
  2. #2 Re: New head unit no sound.
    SWPA
    You answered your own question. You need the proper harness.
  3. #3 Re: New head unit no sound.
    With the Bose system in these cars, there is the 4 wire harness that unplugs out of the back of the stock radio but doesn't plug into the harness adapter. In this harness is a pink wire, connect the power turn on lead from the aftermarket head unit to the pink wire.
  4. #4 Re: New head unit no sound.
    A hammer will fix this.
  5. #5 Re: New head unit no sound.
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Slick is 100% right i had the same problem. Connect the pink wire from the small harness to the amp turn on lead from the head unit, usually blue.
    Sent from my SPH-L720 using Tapatalk
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  6. #6 Re: New head unit no sound.
    Jun 2015
    El Paso
    Awesome got it running now! Any idea what those other three wires in the second harness do? And can I program the auto shut off?
  7. #7 Re: New head unit no sound.
    Iirc they have something to do with the display in the hud. And what auto shutoff are you talking about?
  8. #8 Re: New head unit no sound.
    Jun 2015
    El Paso
    The one where the radio stays on after the engine is turned off. The radio can support it but not sure how to get it to work.
  9. #9 Re: New head unit no sound.
    GTP Level Member simbah's Avatar
    Lala land
    That is part of the programming in the car, RAP, or retained accessory power. If you have the radio wired up correctly it should stay on after the car is shut off, until you open a door or about 10 minutes, which ever comes first.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  1. Just put my new head unit in..
    By FriboRage in forum Audio, Security & Visual Electronics
    Last Post: 10-11-2012, 04:37 PM
  2. Head unit x-over
    By ajoliver2010 in forum Audio, Security & Visual Electronics
    Last Post: 06-25-2012, 02:22 PM
  3. Head Unit In 02 GP
    By stuntsiderida100 in forum Audio, Security & Visual Electronics
    Last Post: 03-11-2012, 01:02 AM
