Thread: alarm and horn
Results 1 to 5 of 5
  1. #1 alarm and horn
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    Horn was working fine till out of nowhere the alarm sound/chirp started to get weaker and weaker and b4 i knew it the horn complety stopped working. I can still here the alarm when unlocking and locking the car doors but very fainted and barely.
    00' GS, and ideas?
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  2. #2 Re: alarm and horn
    GT Level Member mguzzo's Avatar
    Buffalo NY
    pull the bumper off. check the grounds
    or install WRX horns behind the grills
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  3. #3 Re: alarm and horn
    When you say the alarm.. do you have an aftermarket or do you mean the single/double beep of the horn?
    If so.. the horns have likely gotten too much dirt in there and you need to replace them.
  4. #4 Re: alarm and horn
    pass side under the head light is the horn, see it sticking out just past the bumper foam. no need to take the bumper off to get to it. i had it off to paint it.
  5. #5 Re: alarm and horn
    Jul 2012
    North Philly
    Its an After market alarm, AutoPage. Auto start still works, doors lock and unlock. The chirp is just very low. Its a coincidence that the horn goes out at the same time as the aalarm chirp sound goes very low
  1. Alarm going off inside car when reaching highway speeds..coolant temp alarm?
    By MattTheBaker123 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-09-2012, 09:39 AM
  2. no horn
    By echarleswhyte in forum Audio, Security & Visual Electronics
    Last Post: 08-13-2011, 08:55 PM
  3. no horn
    By waltvmac in forum General Tech Discussion
    Last Post: 04-10-2011, 07:25 PM
  4. Horn
    By 400kmtd in forum Introductions/Noob Questions
    Last Post: 09-16-2010, 11:54 PM
  5. Horn Help
    By PhilsGTX in forum General Tech Discussion
    Last Post: 03-07-2009, 10:03 PM
