Thread: Bad electrical issue? Need help.
Results 21 to 40 of 42
  1. #21 Re: Bad electrical issue? Need help.
    Apr 2015
    NJ
    Does it matter if I unplug the battery current sensor? Cuz I already did and there was no change in the cars problems.
    Not sure, frankly im a little vague on what it actually controls, i just know that theres two models depending on the BCM feed voltage.
  2. #22 Re: Bad electrical issue? Need help.
    GXP Level Member
    Mar 2015
    Tomball
    The current sensor measures current to control the charging strategy of the alternator. Operating voltages of 12.5-15.1 are normal for 04+.
    Jeff
  3. #23 Re: Bad electrical issue? Need help.
    Wichita
    Well I replaced the sensor. Car still isn't running right. And it's gotten to the point were it has to be jumped to be started. Even if you just charged it for 3 hours and then drove it. If you try to start it right back up it won't even start. If you think it's the battery its tested good on the cR several times recently. But I'll get it tested off the car today just because. It's looking like this car's gonna have to go to a shop, cuz I'm stumped.
  4. #24 Re: Bad electrical issue? Need help.
    SWPA
    If the car will start on a jump, then won't start after running then there is a dead cell in the battery.
  5. #25 Re: Bad electrical issue? Need help.
    Enfield, CT
    X2.
    Sent from my LG G3
  6. #26 Re: Bad electrical issue? Need help.
    Wichita
    ^^^Looks like you're both right. My dad took the battery out of his Nova & put it in the GXP. No more problems.
  7. #27 Re: Bad electrical issue? Need help.
    Apr 2015
    NJ
    Curious as to how it tested good with a dead cell, the issue your experiencing is the fact that the battery isnt putting out 12v. lol What brand battery was it? If you havent gotten a replacement yet, I recommend a 26R, fits in the battery tray perfectly, but is shorter and not as wide, making it alot easier to get in and out when need be.
    Just make sure if you buy one it has the terminals on the correct side.
  8. #28 Re: Bad electrical issue? Need help.
    GXP Level Member
    Mar 2015
    Tomball
    I'm surprised you didn't get the security warning.
  9. #29 Re: Bad electrical issue? Need help.
    Wichita
    Well I got a new battery. Car ran great until After I stopped to get gas omw home. It shifted real bad at an intersection & the MPH needle started to bounce. Wth?
  10. #30 Re: Bad electrical issue? Need help.
    SWPA
    Disconnecting the battery reset all your trims so your ECU has some relearning to do. I would also check the connections and make sure they are properly tightened.
  11. #31 Re: Bad electrical issue? Need help.
    Wichita
    Connections are very tight.
  12. #32 Re: Bad electrical issue? Need help.
    Apr 2015
    NJ
    Verify all your grounds are good, you should have one that goes to the block under the front manifold, one on the front of the transmission, and the main ground should bolt over to the trans on the drivers side somewhere, honestly i forgot what the exact location is, ill have to take a look under the hood of my car. What's the condition of everything under the hood? When I bought mine I had massive electrical issues mainly related to the harness itself, mainly from neglectful mechanic work, and just piss poor quality of the loom that GM uses on their harnesses. I had several sections of cut and frayed wire that were merely the result of wear and tear from constantly being exposed to heat and rubbing against the engine. If you have sections of your wiring harness that the loom has corroded and failed, check for frayed wires. The main positive and ground wires coming off the battery also run next to the radiator and in front of the pulley system, and there is a large loom of wire that runs from the fuse block over the belt on the pulley side that could potentially have made contact.
  13. #33 Re: Bad electrical issue? Need help.
    Apr 2015
    NJ
    Your main positive and negative cables on the battery are an independent harness from the engine harness itself, heres a few of the connections on the main cables.
    and a picture of that harness
  14. #34 Re: Bad electrical issue? Need help.
    Wichita
    Thank you for the images! I'll be able to use this and check all my grounds either Friday or Saturday & I'll let you all know what I find out ok.
  15. #35 Re: Bad electrical issue? Need help.
    Wichita
    All the connections checked out. Even got a new wheel speed sensor. Still have a problem.
  16. #36 Re: Bad electrical issue? Need help.
    Apr 2015
    NJ
    Hmmm, at a loss here, only thing I can really think of at this point is a harness problem or a module problem. Only other cheap fix I can recommend is clean every connection at every module (ECU, TCM, BCM, etc) with deoxit 100 to make sure all the connections are solid where they plug in.
    http://www.amazon.com/Hosa-D100S-2-D...9NT8B2N32G7JSR
    https://www.youtube.com/watch?v=ITBwoFq_zps
  17. #37 Re: Bad electrical issue? Need help.
    Wichita
    So this morning I went ahead & left the GXP @ a local transmission shop. They're a place that I've had dealings with before & the folks there are fairly familiar with W Bodies. So Im really hoping they can figure out what's wrong.
  18. #38 Re: Bad electrical issue? Need help.
    Wichita
    Shop said they're done with GXP. Seems they checked all the connections & all of the wiring harness & couldn't find anything wrong. They tell me they test drove it a few times & didn't experience any problems. We'll see...
  19. #39 Re: Bad electrical issue? Need help.
    Wichita
    Got the GXP back today. So far it seems to run great. All the shop did was pull & inspect the wiring harness & check the connections. So, fingers crossed then, yea?
  20. #40 Re: Bad electrical issue? Need help.
    Apr 2015
    NJ
    Like i said before, its possible it was a corroded connection and pulling the wiring harness could have alleviated that issue temporarily. I'd clean all the connections with deoxit100 to make sure they are all getting good contact.
  1. Electrical Issue
    By TEK310 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2013, 05:32 PM
  2. Odd electrical issue
    By SDGTP99 in forum General Grand Prix Discussion
    Last Post: 07-02-2012, 08:01 AM
  3. new electrical issue on 02
    By powdercoater46 in forum General Tech Discussion
    Last Post: 09-02-2011, 05:41 PM
  4. VERY ODD electrical? issue
    By Pittman06 in forum General Tech Discussion
    Last Post: 01-18-2010, 07:30 PM
  5. electrical issue
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 12-10-2009, 10:49 PM
