No manifold is a direct plug and play. What's needed is any 05 and prior truck intake you can use the stock fuel rail if you can use the truck rail but you must grind out the alternator bracket.
smoothing of the top isn't mandatory depending on your preference. Keep in mind though your hood may or may not rub
A Tb adapter is needed from eBay and a retune.
