Thread: Need Brakes for my GXP
Results 1 to 9 of 9
  1. #1 Need Brakes for my GXP
    GT Level Member comatoast's Avatar
    Nov 2012
    MN
    havent had a time to really look at it closely, but when it was on the lift I noticed that on the passanger side the rotor on the inside was reaaalllly rough, lots of grooves, while the outside was nice and smooth.. Dunno if the caliber is sticking or what.. but just looking for a good NOT racing, $500 set of pads and rotors.. But something with a good reputation.. I might need calipers too, but at the moment Im not sure whats going on with the passanger side
  2. #2 Re: Need Brakes for my GXP
    I bet they were just pad slapped in the past, that can screw rotors up pretty good.
    If you want to go with NON drilled rotors (which I prefer) ask a parts store for some front brake rotors from a Buick Allure (super) with the V8. They have the same size front brakes but with just regular discs. Then grab a set of pads. You can double check rotor size if you want, but I'm 99% sure they are exacly the same.
  3. #3 Re: Need Brakes for my GXP
    Arizona
    Take the bolts out clean and lube the pins get some decent pads and have the rotors turned....yes you can resurface crossdrilled rotors
  4. #4 Re: Need Brakes for my GXP
    If they are grooved bad like he says they are, they are likely out of spec by now and being a minnesota car they are likely rusty and not worth it to try and keep them.
  5. #5 Re: Need Brakes for my GXP
    Nov 2012
    MN
    Thanks guys.. Yea the inside of that one is toast... Not sure why yet. I usually just "pad slap" every brake job I do and have never had a sticking caliper issue in the past... But now its time for me to actually start paying attention to the calipers. I dont really know how to do a proper brake job apparently lol
  6. #6 Re: Need Brakes for my GXP
    Rockauto has calipers if you're wanting to get new ones.
    Pretty decently priced as well.
  7. #7 Re: Need Brakes for my GXP
    Nov 2012
    MN
    I'll pull them apart this weekend and see if anything looks off. Car stops great. No squeeks or grinds. All the other rotors are smooth, just the inside passenger is goofy...
    Thanks. I forgot about rock auto. I was looking at some. Ebc? I believe they were ebc , for $190 for the set that looked really nice as well. Match those with some hawk pads and call it a day.
    Also is it worth bringing it to a dealer to have it on a tech 2 to completely flush the system, or no? 8+ years old , and 170k miles and I'm sure it original fluid.
  8. #8 Re: Need Brakes for my GXP
    Feb 2009
    flintnasty MI
    I have a pair of front pads and rotors for sale nos oem !!! They have miles on them but less than 100.
  9. #9 Re: Need Brakes for my GXP
    Just do it the red neck way, suck some fluid out and dump new fluid in. Drive it for a week or so and do it again.
    Go drive on a dirt road or something aswell and stomp on them to cycle the ABS pump on and off a bajillion times to push new fluid around.
  1. Brembo brakes or f-body brakes? Any other choices?
    By LAST2DOOR in forum Brakes/Suspension/Chassis
    Last Post: 09-26-2013, 10:37 PM
  2. 05 Brakes
    By Moe Dubs in forum Brakes/Suspension/Chassis
    Last Post: 12-28-2012, 07:24 PM
  3. Brakes squealing even after foot is off brakes
    By GTLGDP in forum General Tech Discussion
    Last Post: 06-26-2012, 09:16 PM
  4. Brakes.
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 08-08-2010, 03:36 PM
