Thread: Power Steering Funtimes
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: Power Steering Funtimes
    Dec 2014
    Montreal, Canada
    The ps pump on my GXP is higher than the reservoir so I wasn't able to completely fill the hose between the reservoir and the pump. Probably why there was air in the system.
  2. #22 Re: Power Steering Funtimes
    clearly you dont know whats going on inside the pump.
  3. #23 Re: Power Steering Funtimes
    Dec 2014
    Philadelphia, PA
    Air can be trapped in the Rack as well as the pump. However, almost always it is an issue where the air is trapped in the PS pump. The way we suggest is the vacuum bleed. By watching the fluid level in the pump when it is running as compared to when you shut the engine off, if the level rises and falls, there is a very good chance of air still trapped in the system.
  4. #24 Re: Power Steering Funtimes
    and that air is trapped in the rack, not the pump.
  5. #25 Re: Power Steering Funtimes
    Dec 2014
    Philadelphia, PA
    Also, here is a GM TSB about Power Steering Bleeding.
    http://workshop-manuals.com/chevrole...owl_noises/ent
  6. #26 Re: Power Steering Funtimes
    Arizona
    The ps pump is not higher than the resovoir. Like not at all higher.
  1. power steering
    By pacothetaco in forum General Tech Discussion
    Last Post: 07-28-2011, 10:15 AM
  2. power steering. feels like i have "half" the power
    By colindunn in forum General Tech Discussion
    Last Post: 07-23-2011, 09:15 AM
  3. Power steering?
    By apierce1289 in forum General Tech Discussion
    Last Post: 03-11-2011, 04:27 PM
  4. Power steering ?
    By blktalon456 in forum General Tech Discussion
    Last Post: 02-22-2010, 03:39 PM
  5. power steering
    Last Post: 04-11-2009, 10:52 PM
