Thread: Auxiliary Electric Fan
Results 1 to 3 of 3
  1. #1 Auxiliary Electric Fan
    May 2014
    Phoenix
    I need some help on how to install an auxiliary electric fan for cooling purposes.
    I understand the push, pull of the fan for cooling purpose but do not know how
    to wire it up to a toggle switch. Thank you.
  2. #2 Re: Auxiliary Electric Fan
    Arizona
    The factory fans will keep you at operating temp....what's your original problem?
  3. #3 Re: Auxiliary Electric Fan
    buy a fog light wire kit, comes with a switch, a relay, inline fuse and all the wire you need. run the power side of the switch to a ignition on only fuse in the fuse box, this way it turns off when the cars off. but you can still turn it off and on when the car is running if you want to.
  1. What auxiliary stereo should I buy?
    By thanksmisfortune in forum Audio, Security & Visual Electronics
    Last Post: 01-29-2013, 08:26 PM
  2. Auxiliary Input / Burn audio cd with ID3 Tags?!
    By E IN v Y in forum Audio, Security & Visual Electronics
    Last Post: 07-03-2011, 06:52 PM
  3. auxiliary power drop
    By macey43 in forum Audio, Security & Visual Electronics
    Last Post: 08-01-2010, 09:47 PM
