Thread: Help Code P0420 Bank 1 Oxygen Sensor Fail
Results 1 to 12 of 12
  1. #1 Help Code P0420 Bank 1 Oxygen Sensor Fail
    SE Level Member sschwaeble93's Avatar
    Apr 2013
    N.J.
    Hi,
    I need help. I have a 2006 Pontiac Grand Prix Gxp and I'm getting a check engine light coming on code P0420 and the service engine
    soon light also pops up on the DIC while I'm driving. I had the car scanned and wanted to know where bank 1 is for the O2 sensor? Thanks
    for your help in advance. Already put a new cat converter in over the weekend but still getting the code.
  2. #2 Re: Help Code P0420 Bank 1 Oxygen Sensor Fail
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    if you put in a generic weld in cat, you may not ever get rid of the P0420 code
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  3. #3 Re: Help Code P0420 Bank 1 Oxygen Sensor Fail
    Apr 2013
    N.J.
    No it is a own fit car. What is the best way to remove the o2 sensor on the exhaust manifold pipe?? Really tight there against the firewall. Thanks.
  4. #4 Re: Help Code P0420 Bank 1 Oxygen Sensor Fail
    That code you gave is for a rear o2 sensor.
    The one after the cat.
  5. #5 Re: Help Code P0420 Bank 1 Oxygen Sensor Fail
    And..the code isn't for a bad sensor.
    Bad sensor codes include ones for sensor slow to respond, bad voltage, heater etc.
    P0420 is the code that says the rear sensor isn't seeing the catalytic doing a good job of reducing the emissions .
  6. #6 Re: Help Code P0420 Bank 1 Oxygen Sensor Fail
    Apr 2013
    N.J.
    Thank you for your help. I will probably just replace both. What is the easiest way to get the upstream O2 sensor removed. I had trouble trying to get it loose from the top. Is it easier to get to it with the car jacked up from underneath. Thank you again.
  7. #7 Re: Help Code P0420 Bank 1 Oxygen Sensor Fail
    you need a o2 socket for the upper one. i got mine out from the top with bout a foots worth of extensions. that got my ratchet right under the cowl and the pipe on the ratchet cleared the engine.
    one of these, got mine at HF for like 7 bucks.
  8. #8 Re: Help Code P0420 Bank 1 Oxygen Sensor Fail
    I have one of these, same basic thing.
    It's 1/2" drive..so a couple extensions and a nice long 1/2" ratchet. I've had one that fought to the point I had the car running while I fought it out.
  9. #9 Re: Help Code P0420 Bank 1 Oxygen Sensor Fail
    mine was just damn tight, once it broke free it came right out, the new one should come with some anti seize for the threads.
  10. #10 Re: Help Code P0420 Bank 1 Oxygen Sensor Fail
    Scott.. did you see which section we are in. Our method for the sensor may not be spot on.. damn 5.3's lol
  11. #11 Re: Help Code P0420 Bank 1 Oxygen Sensor Fail
    in another thread 91parkave i think it is, said its in the same place on a v8. exhaust is pretty much the same. same with the banks and locations. 1 and 2
  12. #12 Re: Help Code P0420 Bank 1 Oxygen Sensor Fail
    Apr 2013
    N.J.
    Thanks to everyone for your feedback. I will let u know how I make out.
  1. trouble code po171 bank 1
    By peter in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2012, 01:21 PM
  2. Where is Bank 1 Sensor 2
    By GTLGDP in forum General Tech Discussion
    Last Post: 12-26-2011, 04:28 PM
  3. P0172 rich mixture bank one. oxygen sensor?
    By colindunn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2010, 06:49 PM
  4. p0420 code, which o2 sensor do i replace?
    By Golman76 in forum General Tech Discussion
    Last Post: 02-15-2010, 10:50 PM
  5. p0420 Catalyst System Efficiency Below Threshold (Bank 1)
    By NaturallySmashed in forum General Tech Discussion
    Last Post: 08-12-2009, 01:05 PM
