Thread: issue with headlights!
Results 1 to 20 of 26
  1. #1 issue with headlights!
    Jul 2011
    Western MA
    Having an issue with my headlights..
    Both aren't working. I checked the fuses and replaced the headlamp relay.
    They still don't work.....they will work after driving for about 15 minutes or so. Very strange.
    Open for suggestions on what to check. Took both headlights out of the vehicle and checked all plugs to make sure nothing is loose or busted wires.
    Owner:
    Chataboutcars.com
    The-blacklist.org
    2007 GP GXP LS4
  2. #2 Re: issue with headlights!
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    column switch, probly next place id look
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  3. #3 Re: issue with headlights!
    Jul 2011
    Western MA
    Update: replaced column switch. Still doesn't work!
    Checked the 10a fuse for the low beam. Although it's not blown I stuck the multimeter in the female part and no power what - so - ever
    No clue where to go from here.
  4. #4 Re: issue with headlights!
  5. #5 Re: issue with headlights!
    Jul 2011
    Western MA
    Thanks.....looks like I'm checking the bcm next. Hope that's it. Getting aggrivated. Thank god I have anot her vehicle to drive with at nivht
  6. #6 Re: issue with headlights!
    Arizona
    Have you thought to check your light sensor on your dash
  7. #7 Re: issue with headlights!
    Jul 2011
    Western MA
    Quote Originally Posted by 91parkave View Post
    The wiring? No. Don't think it would be the issue as I can't even turn them on manually?
    Anybody know someone in western MA that can scan the BCM...the dealership is probably gonna rape me
    Owner:
    Chataboutcars.com
    The-blacklist.org
    2007 GP GXP LS4
  8. #8 Re: issue with headlights!
    I'm in western MA but don't believe headlights is included in HPT (scanner). Did you check the ground up behind the headlight? Recently helped another local and he found the ground to be an issue.
  9. #9 Re: issue with headlights!
    Jul 2011
    Western MA
    Hmmmm.....I did not. I'll check that out when I have a few minutes. Thanks
    Owner:
    Chataboutcars.com
    The-blacklist.org
    2007 GP GXP LS4
  10. #10 Re: issue with headlights!
    It's the ground right behind ....I think the driverside headlight on the radiator support.
  11. #11 Re: issue with headlights!
    Arizona
    You'll have to remove the headlights there's a ground point directly in front of the opening on both sides. 10mm bolts and no hpt can't scan for that unfoutenatley
  12. #12 Re: issue with headlights!
    I meant to control it. Like it can fans etc. Pretty sure headlamps aren't available though.
  13. #13 Re: issue with headlights!
    Jul 2011
    Western MA
    Checked the ground (located directly under headlight once taken out) definitely not the case. Looked fine
  14. #14 Re: issue with headlights!
    GT Level Member atj8's Avatar
    Midwest
    Quote Originally Posted by Godfather View Post
    did you end up finding out what it was? my buddy has the same exact issue..we've done everything, still cant figure it out..thanks!
    98 GTP Gen v 2.8,FSIC,xpcammed,SD headers,CAI,CORNFEED,TIMBOKU TUNED
    04 Comp-g Turbo,Cornfed, TIMBOKU tuned
  15. #15 Re: issue with headlights!
    Jul 2011
    Western MA
    Quote Originally Posted by atj8 View Post
    nope...still haven't figured it out. Let me know if you do!
    Owner:
    Chataboutcars.com
    The-blacklist.org
    2007 GP GXP LS4
  16. #16 Re: issue with headlights!
    Jul 2011
    Western MA
    Check for recalls....got a recall notice in the mail a few weeks ago - sorry for bumping old thread just don't want someone to have same issue and go nuts like I did
    Owner:
    Chataboutcars.com
    The-blacklist.org
    2007 GP GXP LS4
  17. #17 Re: issue with headlights!
    Jul 2011
    Western MA
    Bump if anyone has come across this yet. Came across this issue with a few hundred people online and not one solution. Haven't had headlights for months now and about to just trade it in
    Owner:
    Chataboutcars.com
    The-blacklist.org
    2007 GP GXP LS4
  18. #18 Re: issue with headlights!
    Midwest
    So we changed the hdm module and no issues. but we think theres something else causing it to go bad...any thoughts???
  19. #19 Re: issue with headlights!
    Enfield, CT
    Where in Western MA?
  20. #20 Re: issue with headlights!
    Did you replace the HDM module??
    I know you said relay but you didnt say if it was the HDM one or not. That module controls all low beam functions for headlights.
  1. Issue with A/C no more cold air and sound issue with Shocks
    By ibra0078 in forum General Grand Prix Discussion
    Last Post: 08-09-2013, 08:25 AM
  2. Wheel Bearing Issue or Tire Issue
    By ibra0078 in forum Tires & Wheels
    Last Post: 06-07-2013, 05:12 AM
  3. No headlights or dash lights when the headlights are turned on. HELP!
    By steeck1 in forum Audio, Security & Visual Electronics
    Last Post: 06-23-2012, 12:08 PM
  4. 97 GTP issue w inside Fan/Blower issue
    By JoeRappa in forum General Tech Discussion
    Last Post: 10-03-2011, 10:16 PM
