Thread: 06 GXP oil leak
Results 1 to 17 of 17
  1. #1 06 GXP oil leak
    Mar 2014
    Angola, IN
    So i just found some obvious oil puddles on the concrete coming from my 06 Grand Prix Gxp with 91,000 miles. I looked underneath it and it looks like its coming from some place above the crank pulley. There's a little oil dripping off the oil pan but its not coming from there its just running off it. There is also some oil coming off the belt tensioner spring so it must be somewhere above that. its not under the crank pulley so not the main seal or oil pan as far as i can see. I'm guessing its leaking from some oil line they ran up the passenger side of the engine. Also there is a little oil on the power steering pump line at the top of the engine. No oil anywhere else that i could see. Anybody else have a similar issue or an oil leak around the same area?? Thanks for any input and sorry if this has been talked about before i couldn't find any info in this exact leak. Thanks again.
  2. #2 Re: 06 GXP oil leak
    Arizona
    Spray brake cleaner all up and down the areas in question get it nice and clean and re examine where your leaking from.
  3. #3 Re: 06 GXP oil leak
    Donating Users timboku's Avatar
    Montgomery, IL
    Check the power steering lines. There was a tsb on replacing the lines for the ps pump cause the xrack and leak. Gm repaired mine twice already for free. Check the ps fluid to see if you are loosing it.
    Sent from my SCH-I545 using Tapatalk
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  4. #4 Re: 06 GXP oil leak
    Montgomery, IL
    Im sorry it was a recall for 05 and 06 gxps and v8 impalas..
    http://m.ls1tech.com/forums/showthre...621&styleid=27
  5. #5 Re: 06 GXP oil leak
    Mar 2014
    Angola, IN
    So right after I wrote the post I checked the power steering and of course its low so that is leaking also so I should be covered in the gm warranty if it's just the line which most likely it is. But it was oil on the bottom of the engine. I checked the oil also and it was a quart and half low. I just checked it a couple weeks ago so I know its leaking cause of the obvious oil puddles. But I'm sure it has some power steering mixed in to the puddles too. Not sure if I have Two leaks in the exact same area or what. Been working too much to jack it up again and clean it off but I will soon hopefully.
  6. #6 Re: 06 GXP oil leak
    de grease the engine and tranny and everything else under the hood. then keep a eye out for wet spots.
    or just drop it off at the dealer. warranty's rule.
  7. #7 Re: 06 GXP oil leak
    Montgomery, IL
    Gxps are always low on oil lol..the burn it like mad..I would get line fixed..clean everything and see if it is still leaking..I have 120k on my gxp..no leaks or drips anywhere.
  8. #8 Re: 06 GXP oil leak
    Mar 2014
    Angola, IN
    So I finally had time to drop my gxp off at Harold chevrolet and they ordered the part and now tell me it's not covered. How is everybody else's covered and not mine??? Who could I double check with to make sure?
  9. #9 Re: 06 GXP oil leak
    Arizona
    What part did they order
  10. #10 Re: 06 GXP oil leak
    Mar 2014
    Angola, IN
    I think the high pressure line. But they typed in my Vin and said nothing came up for recalls. They said it could be made a certain month and have no recalls then the next month could have that recall and be covered. Sounds like something shady to me. Lol
  11. #11 Re: 06 GXP oil leak
    Montgomery, IL
    Where do you live? It was for northern climate cold weather cars...not sure if that makes a difference..thats what my dealer said. Ive had mibe repaired twice with no issues..high pressure steering hose.
  12. #12 Re: 06 GXP oil leak
    Mar 2014
    Angola, IN
    I live in Angola which is in northeast Indiana right near the Michigan/ohio border. So don't see why this recall doesn't include me.
  13. #13 Re: 06 GXP oil leak
    Mar 2014
    Angola, IN
    I ordered the high pressure hose from advance so it will be there later today so I might just do it myself and save the headache with the recall. But it would be nice to get an explanation why my car isn't covered because the line does not look like it's gonna be fun to replace.
  14. #14 Re: 06 GXP oil leak
    I live here. DirtDog's Avatar
    Jun 2012
    just throwing it out there...the recall is no longer valid. the end date to get the recall done for free by was i think end of February. right after i got my line replaced.
  15. #15 Re: 06 GXP oil leak
    Montgomery, IL
    Ive never heard of recalls running out..I brought my 97gtp with 160k on it last year to gm for a rack and pinion recall and they fixed it along with the valve cover gasket...maybe its the dealership being good to me??? Ive had my gxp power steering line replaced twice for free by my dealership..it was last done 10/13 when they installed my 3rd transmission under warranty..they actually told me it was leaking a little. The new power steering line is redesigned as well. The new one they put on is way different.
  16. #16 Re: 06 GXP oil leak
    Mar 2014
    Angola, IN
    So I finally got the leaking power steering line fixed. Ended up being the o ring right at the pump. Couldn't tell cause fluid was all over every time I go to check it. But got it fixed and got to return the pressure line I bought so got to save a few bucks there. Just had to pull the belt off, the pump and pulley. Got to the oring and replaced it. All back to normal now. Thanks to everyone for there input and help.
  17. #17 Re: 06 GXP oil leak
    FWIW most of the LS motors benefit huge from a catch can.
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
