So i just found some obvious oil puddles on the concrete coming from my 06 Grand Prix Gxp with 91,000 miles. I looked underneath it and it looks like its coming from some place above the crank pulley. There's a little oil dripping off the oil pan but its not coming from there its just running off it. There is also some oil coming off the belt tensioner spring so it must be somewhere above that. its not under the crank pulley so not the main seal or oil pan as far as i can see. I'm guessing its leaking from some oil line they ran up the passenger side of the engine. Also there is a little oil on the power steering pump line at the top of the engine. No oil anywhere else that i could see. Anybody else have a similar issue or an oil leak around the same area?? Thanks for any input and sorry if this has been talked about before i couldn't find any info in this exact leak. Thanks again.
