Thread: P0449 Code (Yep, again)
Results 1 to 4 of 4
  1. #1 P0449 Code (Yep, again)
    SE Level Member ThaUnknownOne's Avatar
    Jun 2013
    Detroit Michigan
    So I have read quite a few threads about the code p0449. I am trying to find a definitive answer on what I need to fix. Some people are saying I have to fix a solenoid that is located in the drivers side rear wheel well. Then I real some people say I have to fix a part on the back of the motor. Then I read I need to pressure test for vaccum leaks. I bought a gas cap from GM so I know that is not it.
    My job has cut hours and I really can't afford to take the car to the shop, so this is one I am going to have to tackle on my own. Does anyone have a answer to this? Also, if it helps any, since my check engine light came on I am 2 miles per gallon less and it seems like the car is DRINKING gas. Help please!
    "When You Get Your Dream Car, You Will Cherish Every Ride Like It's Your Last"
  2. #2 Re: P0449 Code (Yep, again)
    Jun 2013
    Detroit Michigan
    Is there no knowledge of this code? Really looking for help on this one...
  3. #3 Re: P0449 Code (Yep, again)
    Arizona
    the solenoid sits right on the intake manifold maake sure its plugged in tight and the hose that runs from it to the side of TB is also intact an secure.
  4. #4 Re: P0449 Code (Yep, again)
    Jun 2013
    Detroit Michigan
    Thank you @91parkave Will check that on my lunch...
  1. P0449 is back again!
    By gagt3100 in forum General Tech Discussion
    Last Post: 04-13-2013, 01:47 AM
  2. bad idle maf code driver 6 line 4 code
    By GTPSHAWTY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-04-2012, 05:56 PM
  3. '99 Grand Prix GT has code 1810, yet runs great as always, so why the code?
    By McFly1999 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-03-2012, 07:52 AM
  4. EVAP Questions P0449
    By jarkayman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-28-2011, 08:05 AM
  5. P0449
    By probuilder1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-01-2009, 06:27 PM
