Thread: DOD disable
Results 1 to 20 of 20
  1. #1 DOD disable
    SE Level Member gtx3800's Avatar
    Gillespie, IL
    I may have stumbled across a way to disable the DOD that anyone can do in their driveway.. After picking up the GXP from Triple Edge I noticed my DOD no longer engaged. I detuned and flashed back to stock before I took it in for the transmission. With no cat the Engine light was always on. Had me worried all the way home that something serious could be wrong. When I got home I plugged in the Tech 2 and found my OPSU was bad. Since the DOD operates on oil pressure and an electrical signal to the solinoids I can only assume if the system can't see oil pressure it's fail safe is to disable. If someone wanted to check my theory they could unplug the OPSU on their intake under their throttle body and see if they get the same result. Granted your Engine light will come on but since mine is on anyway it doesn't both me.
    THERE IS NO REPLACEMENT FOR DISPLACEMENT!
  2. #2 Re: DOD disable
    DOD?
    SMGPFC Member #10
  3. #3 Re: DOD disable
    Out West
    Department of Defense
    Whine with your Cheese?
  4. #4 Re: DOD disable
    Jun 2011
    Detroit, MI
    displacement on demand. not sure.
    iLoveSpade
  5. #5 Re: DOD disable
    on a gp wtf?
    is that like a federal truck, have different emissions and programming laws?
    SMGPFC Member #10
  6. #6 Re: DOD disable
    Out West
    lol
  7. #7 Re: DOD disable
    oh you were ****ing with me werent you????
    you sonofa*****...
    SMGPFC Member #10
  8. #8 Re: DOD disable
    Jun 2011
    Detroit, MI
    Displacement on Demand!! It's on the V8's. OP don't worry about it, it saves you little gas, many people like it to be disabled.
    iLoveSpade
  9. #9 Re: DOD disable
    GTX Level Member f3racer's Avatar
    dongducheon, south korea
    disable it. you'll never miss it.
    SSG US Army Military Police
    2006 Grand Prix GXP
    http://gmls4.com
  10. #10 Re: DOD disable
    Gillespie, IL
    I don't miss it. Car runs much smoother now.
  11. #11 Re: DOD disable
    Pennsylvania
    If you would just pay attention to which forum you're posting silly questions to, Hippo wouldn't have to come in and teach you about cars.
  12. #12 Re: DOD disable
    SE Level Member b2crzy's Avatar
    Nov 2012
    Flood City, PA
    Quote Originally Posted by gtx3800 View Post
    I want to disable the DOD on my GXP but don't want the Engine Check Light on all the time as a result. Anyone know any other ways to accomplish this? Right now it runs great, but I hate the DOD system kicking in at low speeds......and the noise the engine makes when I'm coasting at idle with DOD engaged....sounds like a bag of bolts! As soon as DOD disengages, it goes quiet and purs like a cat - anyone any ideas? Thanks.
    Flood City, PA
    Pontiac GXP
    Porsche 928
  13. #13 Re: DOD disable
    Arizona
    Quote Originally Posted by b2crzy View Post
    Pay somebody with HP tuners in your local area or get a diablo tuner
  14. #14 Re: DOD disable
    Nov 2012
    Flood City, PA
    - - - - - UPDATE - - - - -
    I have found a local 'tuner' who is able to disable the DoD system on my GXP. I will be getting this done tomorrow and will report back my experience (which will hopefully be positive). He said he is going to set the temperature setting really high so it never allows the DoD system to activate. This should disable the system without throwing any error lights. We shall see.....
    Flood City, PA
    Pontiac GXP
    Porsche 928
  15. #15 Re: DOD disable
    Nov 2012
    Flood City, PA
    - - - - UPDATE #2 - - - - -
    Okay, was finally able to get my GXP tuned and DoD disabled (a simple 'disable DoD' check box in the tuner software apparently!)....and it is SO much better - none of that stupid noise and engine bogging down - plus I'm hopeful this will reduce or eliminate my oil consumption issue.
    While he was in there - he also changed some other settings - tightened up the shifts at wider throttle opening (much quicker shifts), more fuel at wide open throttle, timing changes, overdrive moved to 55mph, and several other small adjustments (fans cut in at lower temp etc). Well worth it and the car is much nicer to drive now. He is charging $250 but being a local guy, mine was a little less for cash and worth every penny!
    Flood City, PA
    Pontiac GXP
    Porsche 928
  16. #16 Re: DOD disable
    Arizona
    Whoaaa theres no temp that dod comes on its a simple drop down that let's you turn it on/off km thinking he's getting it confused with dfco (deceleration fuel cut off)
    BTW how much is he charging
  17. #17 Re: DOD disable
    Been there...done that..
  18. #18 Re: DOD disable
    your ol consumption issues is seperate. Many with your motor run an external catch can.
  19. #19 Re: DOD disable
    Nov 2012
    Flood City, PA
    Where and how?
    I've read and been told by several mechanics that disabling the DoD can prevent the oil loss.....where else is it going?
    Flood City, PA
    Pontiac GXP
    Porsche 928
  20. #20 Re: DOD disable
    Arizona
    Dod disabling will slow down your oil loss for sure. But the pcv design on our vehicles suck up mad amounts of oil. Fix those two and you will be golden
  1. DRL Disable!!!!
    By 1SICKGP in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-29-2010, 12:16 PM
  2. How to disable DRLs
    By 3800pontiacmuscle in forum Visual/Body Modifications
    Last Post: 08-06-2010, 10:54 PM
  3. disable dic messages?
    By BoostedComp in forum 04+ Specifics
    Last Post: 12-05-2009, 02:29 PM
  4. DRL disable procedures?
    By Cowboybebop in forum General Tech Discussion
    Last Post: 07-22-2009, 09:41 AM
  5. DRL disable
    By 99prixgt in forum Visual/Body Modifications
    Last Post: 12-16-2008, 09:33 AM
