Thread: First drive with Ported Ls1 intake and LS2 TB
Results 1 to 4 of 4
  1. #1 First drive with Ported Ls1 intake and LS2 TB
    Arizona
    So started the car up today for the first time with the new ported LS1 intake and 90mm TB combo, must say throttle is way more touchy than before nowhere near as linear as the LS4TB combo was, drove it to wal mart an back just to see if everythingwas working fine i can barley go above 20% throttle without dumping fuel, which is as expected especially with the LS6 injectors.
    I did run into some issues after the first start which boiled down the throttle blade getting stuck at full close which then threw the car into a reduced power setting even after clearing codes i was still perplexed took everything off double checked connections etc.... well i guess with the LS4 programming it slams the TB blade all the way before coming back open when you shuut the car down this was causing the blade to get stuck in the weird recesses of the TB. after cursing at the car for half the day i found that the blade was actually making contact with the bore it self so i HAND sanded those areas and repolished the surface so it would never stick again
    As for the intake swap that was good except the alternator bracket i ended up chopping on the car, never took it off just covered the cylinder heads and went to work. worked out just fine as for the MAP i located it in the rear of the manifold and just peeled the wiring back for it out of the factory loom. no need to buy some harness. Also the TB adapter needed some grinding on right edge to avoid hitting the heater hose lines. ALSO i would highly recomend re taping your Factory loom before taking off the intake manifold there so many pices of factory loom that cracked and fell everywhere when i was trying to take off the manifold it wasnt even funny. save youreself some time and prevent all those plastic pieces from getting into the intake. otherwise once i start getting my VE and MAF where they need to be ill give some more final results on the swap Thanks to all that could help and have given me great advice over the almost year now of having the GXP.
    Here are some pics BTW a 8mm wrench ratchet will save you some valuable time taking the intake off
    [URL=http://s173.photobucket.com/user/91parkave/media/IMG_20130504_113802_565_zps064efa55.jpg.html]
    The stupid ALternator bracket
    [URL=http://s173.photobucket.com/user/91parkave/media/IMG_20130504_113815_895_zpsfc008c89.jpg.html]
  2. #2 Re: First drive with Ported Ls1 intake and LS2 TB
    I live here. DirtDog's Avatar
    Jun 2012
    looks good man. did you get any videos of it yet
  3. #3 Re: First drive with Ported Ls1 intake and LS2 TB
    Arizona
    Just startup no driving though cause I'm still getting the car dialed in
  4. #4 Re: First drive with Ported Ls1 intake and LS2 TB
    Dec 2012
    wichita,ks
    I would like to know to, how much fuel is it eating now?
    It is just a FAMILY CAR
  1. ported lower intake manifold
    By 98buicksupercharged in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2012, 09:15 PM
  2. L36 ported lower intake manifold? Milzy Motorsports
    By ImColeTrickle in forum General Grand Prix Discussion
    Last Post: 02-09-2012, 07:08 PM
