Thread: Gearing questions plus more title might need updating
Results 1 to 5 of 5
  1. #1 Gearing questions plus more title might need updating
    Dec 2012
    wichita,ks
    Can I use these gears? I want more top end pull and my gears aren't doing it lol my factory gears should be 3.29's correct will I see much of a change with 3.69's?
    ZZPerformance - Gear Ratio Conversion Kit #ZZ-GRCK
    It is just a FAMILY CAR
  2. #2 Re: Gearing questions plus more title might need updating
    You will lose top end in the car if you put in 3.69's. Being a lower gear ratio they will help you get moving from a dead stop and take more power/rpm to keep you moving at higher speeds.
  3. #3 Re: Gearing questions plus more title might need updating
    I'm pretty sure the GXP's have the 2.93 gears as its pretty much the same trans as the regular GTP and GT (supercharged) transmission.
  4. #4 Re: Gearing questions plus more title might need updating
    Arizona
    If you want top end get cammed
  5. #5 Re: Gearing questions plus more title might need updating
    Dec 2012
    wichita,ks
    My issue with cam is 700$ plus another 1300 to install lol I could go spray before that lol
  1. Updating head unit in 2007 GT
    By oosena in forum Audio, Security & Visual Electronics
    Last Post: 06-20-2012, 02:24 PM
  2. Updating Viewed Threads?
    By Confusingboat in forum Forum Bugs/Suggestions
    Last Post: 03-01-2011, 04:13 PM
  3. Gearing question.
    By Wakeboy1337 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-10-2011, 11:54 AM
  4. Anyone run 3.05 gearing (Buick)?
    By Lawngoose in forum PCM Tuning
    Last Post: 12-16-2009, 12:06 PM
  5. UserCP not updating information?
    By SD GTP in forum Forum Bugs/Suggestions
    Last Post: 02-18-2008, 01:44 PM
