Thread: How to drain
Results 1 to 19 of 19
  1. #1 How to drain
    I live here. DirtDog's Avatar
    Jun 2012
    So I am changing the type of coolant I use in my engine after doing some extensive reading and searching on it. I have been told that there is a drain somewhere on the engine other than the radiator one that is meant for draining almost all coolant from engine. Does anyone have an ideal as to where this drain plug is on the engine block?
    Sent from my pager using Morse code. ... .. ... ....
  2. #2 Re: How to drain
    Not sure there is one on the 5.3, on the 3.8 you could remove a knock sensor and drain most of the block.
    I would just remove the rad hoses and drain the rad.
  3. #3 Re: How to drain
    Jun 2011
    ahhhh 5.3 nvm then...
    This be what i did for 3.8
    heli plug on drivers side of rad.
    You wont get all of it, but what i did was mix in some 50/50 let it run for a few then re drain.
    Done.
    Jun 2012
    I've been searching and I found a pic on ls4 forum off some manual that says there's one on both sides of engine specifically designed for draining. But in my GM repair manual I can't seem to find them. I want to do a through flushing of the system to get all the old orange out.
  5. #5 Re: How to drain
    if your changing fluid types, you want to do more then drain the old coolant, you want to flush it clean, then use the new brand of coolant.
    Jun 2012
    I got this stuff from oreillys that after u drain the old coolant and flush several times with water to where only water is in the system u pour it in and run it for 100-150 miles then drain flush several more times and then add the new coolant. Just would like to find those drains so I can completely get as much old as possible out
  7. #7 Re: How to drain
    well if your flushing it, you dont need to drain it really.
    take your T stat out, and then put the housing back on, then take the upper hose off the rad, open the rad cap, start the car, coolant will pour from the upper hose.
    have a hose handy, when the rad gets real low on coolant, put the hose in the rad, run it till clear water comes out the upper hose. then add your flush cleaner, drive it, do this again, to flush out that crap. after you got clear water again, turn the hose off, and run it till the water stops coming out the hose, then shut the car off, add your new coolant to the rad, and put the t stat back in. put the hose back on the rad, top off bleed it if you got one of them things, and off you go.
    Jun 2012
    Hmmm...that does sound ally simplier. I'll do it that way. I guess since I'll have to take t-stat out might as well replace it anyways. They ain't to expensive. I just don't have access to a water hose is the only problem with doing it that way....or I could wait till summer and do it when I'm home
  9. #9 Re: How to drain
    you can get a coolant tester to see how cold its still good for, quite cheap really, 10 bucks or so.
    but being your in the south im sure you could wait till summer time.
    Jun 2012
    I've actually already got a coolant tester. It was cheap and simple as heck to use. I just don't have a water hose to do it the way u stated to above unless I'm at home in TN
  11. #11 Re: How to drain
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    Pardon my ignorance, but on my 3.8 if I want to change the t-stat, will any coolant be lost? I believe I have a cooler t-stat than stock and its throwing a code.
    Jun 2012
    Quote Originally Posted by LS1GTP View Post
    Its all good. On the 3.8 yes u will loose some but not much. The t-stat is on the upper rad hose exiting the engine
  13. #13 Re: How to drain
    Sep 2012
    Clarkston, MI
    Ok good.
    Jun 2012
    Found it finally. I'll post up the pick of location of drain bolt in a few minutes. Just in case anyone else ever needs the info
    Jun 2012
    Under the headers on front of engine it looks like to me
    Bunnell, FL
    Might help if you source the pics from gpona
    I'm a Sex Offender
    Jun 2012
    Quote Originally Posted by marines542 View Post
    Found it finally from gpona. I'll post up the pick of location of drain bolt in a few minutes. Just in case anyone else ever needs the info
    Bunnell, FL
    That was the original
    I'm a Sex Offender
    Jun 2012
    Yes thank u for helping to. Its exactly what I needed lol
    And I left the original up there
  1. HID Battery Drain
    By Lishap in forum 04+ Specifics
    Last Post: 06-18-2012, 11:53 AM
  2. I think my AC drain is plugged ?
    By Y2KGTP in forum General Tech Discussion
    Last Post: 04-18-2011, 12:40 PM
  3. transmission drain
    By mhartwig in forum General Tech Discussion
    Last Post: 11-22-2010, 07:40 PM
  4. radiator drain o-ring size? FAILED motormite drain.
    By alacran in forum General Tech Discussion
    Last Post: 04-03-2010, 08:16 PM
  5. Oil drain plug
    By SlowM90 in forum General Tech Discussion
    Last Post: 12-22-2009, 12:05 PM
