Thread: Replacing Crankshaft Position Sensor
Results 1 to 7 of 7
bjm306 Replacing Crankshaft Position... 12-12-2012, 01:03 PM
DirtDog Go to gpona.net and create an... 12-13-2012, 11:29 AM
199730th Re: Replacing Crankshaft... 10-19-2014, 04:51 PM
91parkave Re: Replacing Crankshaft... 10-19-2014, 06:49 PM
aligater Re: Replacing Crankshaft... 10-19-2014, 09:01 PM
199730th Re: Replacing Crankshaft... 10-19-2014, 11:26 PM
91parkave Re: Replacing Crankshaft... 10-20-2014, 12:01 AM
  1. #1 Replacing Crankshaft Position Sensor
    Michigan
    I have a check engine light that is intermittent. The code is PO335 crankshaft position sensor. Where is it located on the GXP motor. I have seen some how to's on replacing it but they are not for the 5.3 motor. Trying to decide it I want to do it myself or take it in. Any help would be great. Thanks
    I live here. DirtDog's Avatar
    Jun 2012
    Go to gpona.net and create an account. Then on top right of their website theres a link for GM repair manuals. Log into that site with the same login u use on gpona. Enter ur vin and it'll pull up repair
    Manual. They are very informative with pics,
    Sent from my pager using Morse code. ... .. ... ....
  3. #3 Re: Replacing Crankshaft Position Sensor
    Aug 2014
    Spruce Grove, Alberta
    hi, so looking at list post a couple years later - and gpona.net is no longer active Has anyone changed out a Crankshaft Position Sensor on a 2006 Grand Prix GXP or Impala SS? I have looked from above the engine, and below the engine - and cant see it? Any tips or pointers would be really appreciated. The only pic I found of its placement is attached. Says it is on drivers side rear of engine. I have removed the tire, and crawled under the car - but no luck.....
  4. #4 Re: Replacing Crankshaft Position Sensor
    Arizona
    Replacing Crankshaft Position Sensor Attached Images
  5. #5 Re: Replacing Crankshaft Position Sensor
    GT Level Member aligater's Avatar
    london ontario canada
    That's showing it to be up in between the trans and the engine. Look up above the the oil pan at the corner closest to the gas pedal. Driver side rear corner.
  6. #6 Re: Replacing Crankshaft Position Sensor
    Aug 2014
    Thanks for the info! Appreciate it. Unfortunately I know where it is supposed to be - but I have no way to see it, or get access to it? I would love to change it out without removing the exhaust manifold.... any chance someone found a way to see/access it? Thanks for all your help.
  7. #7 Re: Replacing Crankshaft Position Sensor
    Arizona
    Quote Originally Posted by 199730th View Post
    Buy some headers, So you can justify to youreself the pain in the ass of removing the manifold lol
  1. crankshaft position sensor help
    By joshuasauce in forum Engine
    Last Post: 07-20-2021, 09:29 PM
  2. Crankshaft Position Sensor
    By pheasant plucker in forum General Tech Discussion
    Last Post: 12-29-2012, 02:18 PM
  3. Crankshaft Position Sensor
    By pheasant plucker in forum Site/Club News
    Last Post: 09-09-2012, 05:02 PM
  4. crankshaft position sensor
    By brian a in forum General Grand Prix Discussion
    Last Post: 05-24-2012, 05:57 AM
  5. bad crankshaft position sensor?
    By ChdMcD in forum General Tech Discussion
    Last Post: 08-13-2010, 01:06 PM
