yeah in that case pull the plugs, clean them, dab some di electrical grease on the plug ends, work that in some. and inspect your wires along the lca's for damage.
if all that checks out it could be a hub is bad.
you can check the hub buy jacking up the wheel, leave the lugs tight, and push and pull the top of the tire, to feel for play. a soft push/pull works best.
