Thread: ls4 throttle body spacer
Results 1 to 15 of 15
  1. #1 ls4 throttle body spacer
    Jan 2012
    Fairbanks, Indiana, United States
    anyone put the 5.3 throttle body spacer on yalls GP?
    i need pros and cons lol
  2. #2 Re: ls4 throttle body spacer
    Waste of money.
    Thats pretty much it.
  3. #3 Re: ls4 throttle body spacer
    Jan 2012
    also does anyone know how i can get a hold of a replacement filter for the cold air inductions intake kit like the one off of PFYC?
  4. #4 Re: ls4 throttle body spacer
    Jan 2012
    is there a throttle body upgrade?
  5. #5 Re: ls4 throttle body spacer
    Can you out flow it??
    I highly doubt it, unless your running a stupid high HP turbo setup.
    Ebay has nice AEM filters, otherwise any high flow, non oiled filter will suffice.
  6. #6 Re: ls4 throttle body spacer
    Dec 2008
    Lawndale, CA
    This should help.
    LS4 Store
    Consider looking into a dry filter like amsoil.
  7. #7 Re: ls4 throttle body spacer
    Dec 2011
    Southern Wisconsin
    Spacers are like "snake-oil" won't help in the least bit.
    Dry filters are preferred since the MAF can easily get coated in oil and cause stuttering/other oddball issues.
  8. #8 Re: ls4 throttle body spacer
    SWPA
    Everyone who says oiled filters can cause MAF problems are just being parrots. I have used oiled filters for over 12 years now and have NEVER had a MAF issue.
  9. #9 Re: ls4 throttle body spacer
    Dec 2011
    Southern Wisconsin
    I actually use a K&N oil based still, I DO have to clean my MAF about once a month, otherwise I get the stuttering and odd RPM fluctuations. It's no myth.
  10. #10 Re: ls4 throttle body spacer
    SWPA
    User error. You are overoiling your filter. I have NEVER NEVER NEVER had oil issues with my MAF.
  11. #11 Re: ls4 throttle body spacer
    Oil filters dont filter as well as paper.
    Is that reason enough not to use them?
  12. #12 Re: ls4 throttle body spacer
    SWPA
    Yet, my brother (as well as several others) ran oil based filters on DIRT TRACK cars and never had a problem. If an oil based filter can handle a dirt track, it can handle a daily driver just fine.
  13. #13 Re: ls4 throttle body spacer
    Dec 2011
    Southern Wisconsin
    Seeing as how it has 10k miles on it and I have yet to re-oil it, meaning it still has the manufacturers application of oil on it, it's not user error. There is plenty of testimonial out there to prove you are a minority when it comes to the MAF issue.
  14. #14 Re: ls4 throttle body spacer
    SWPA
    Its the other way around. You are only going to see people post who have problems. People aren't going to post when they don't have problems.
    I belong to other forums and there are probably 10,000 members with oil base filters and maybe 2 or 3 have had problems. Its not a common issue. Its only an issue if the filter is over oiled.
  15. #15 Re: ls4 throttle body spacer
  1. Throttle Body Spacer
    By Pshnmeawy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-14-2010, 01:17 AM
  2. throttle body spacer
    By danross in forum General Tech Discussion
    Last Post: 02-19-2009, 06:40 PM
  3. throttle body spacer
    By NKYspdemon in forum Off Topic Discussion
    Last Post: 06-30-2008, 08:45 PM
  4. Throttle Body Spacer
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2008, 06:21 PM
