Thread: Platinum Plugs vs. Iridium Plugs
Results 1 to 8 of 8
  1. #1 Platinum Plugs vs. Iridium Plugs
    Independence, Missouri
    Time to change plugs on my '06 GXP and I was looking into replacing original plugs with OEM Platinum or paying a little more and upgrading to Iridium plugs. Anyone have any special preference or insight that may help??? Most of what I've read as far as difference is only the lifespan between the two. Not having any big issues right now with performance or fuel economy. Obviously, new plugs will offer some improvement, but any noticeable responsiveness or improved economy, etc between the two to justify the extra cost??? Also planning on changing the wires while I'm at it. Waddaya think??? OEM or go with a performance set???
    Thanks!!!
  2. #2 Re: Platinum Plugs vs. Iridium Plugs
    I thought the stock plugs for the GXP are AC Delco Iridiums.
  3. #3 Re: Platinum Plugs vs. Iridium Plugs
    HAHA!!! Shows how much I payed attention!!! Did not know that--haven't really done a whole lot of research on it yet, just started, so. I will check into that, if so, problem solved!!! Thanks!!!
  4. #4 Re: Platinum Plugs vs. Iridium Plugs
    GT Level Member Cocor's Avatar
    Aug 2012
    Collinsville, il
    Iridium.
    2005 GP GXP Ivory White, OBX Headers, Cat and Muffler delete, HP Self Tuned, De-badged/Custom LS4 badges, K&N CAI, Intense Poly upper mounts, Strut Tower Braces, HSRK, HID 8000k headlights, Switchback LED front turn signals, interior LED's. Dyno'd @ 275whp/275wtq
  5. #5 Re: Platinum Plugs vs. Iridium Plugs
    Dec 2011
    Southern Wisconsin
    The NGK Iridiums are probably the best plug to use on the LS4. Delco ones should be fine as well.
    I live here. DirtDog's Avatar
    Jun 2012
    The stock for the 5.3ls4 are AC delco iridium ansld personally I recommend sticking with those and I have performance wires on. Runs great like that
    Sent from my DROID RAZR using Tapatalk 2
  7. #7 Re: Platinum Plugs vs. Iridium Plugs
    May 2008
    Winnipeg, MB
    When should the plugs be changed? 3800 III, still running my stock ones after 50K miles.
    2007 Pontiac Grand Prix
  8. #8 Re: Platinum Plugs vs. Iridium Plugs
    factory plugs should last about 100,000 miles, thats when they call for the fist tune up. my last new truck i swapped them out at 70,000 ish, just because it seemed like a good idea. they still looked good.
    i took gregbadass to pick up a car he bought, a 98 gtp, it had like 80,000 on it, all original plugs and wires, i test drove it 3 days before he came in to buy it and it ran fine, 3 days later it was misfiring all over the place, we did a quick tune up, and the car was like new again.
    so they say 100,000 but they could last less then then that. as greg and i saw 1 st hand.
  1. plugs
    By leigh in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-30-2012, 12:31 AM
  2. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  3. Pulstar Iridium Spark Plugs
    By UCF04GPGTPCompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-25-2011, 04:27 PM
  4. Autolite XP103 Xtreme Performance Iridium Spark Plugs
    By deadsnake in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-05-2010, 10:57 AM
