Thread: *HOW TO* LS6 Intake Manifold Swap
Results 1 to 20 of 32
  1. #1 Re: Successful LS6 Intake Manifold Swap, DOD Retained
    Jul 2008
    Germantown, Maryland
    Quote Originally Posted by ford sucks View Post
    i know its old but did you have any cal issues after you swapped intakes?
    and could you pm me the contact info for the guy that did your tuning.
    JDMC is over on LS1tech.... he posts a good amount so just hit the LS4 Front Drive section and you will find him, he has the same name.
  2. #2 Re: Successful LS6 Intake Manifold Swap, DOD Retained
    Jan 2009
    Farmington Hills, MI
    Yeah I had to retune. It helps to have someone show you the basics, which Jesse did for me. After you kinda get the hang of things, you can start searching and posting on the HP Tuners Forums for more advanced or specific stuff. Jesse is cool; I picked up a friend out of the deal too. He was just over this weekend helping me work on my cam swap. But, if you can't find someone close to you to help you get started, I highly recommend going to the library or the bookstore and picking up Greg Banish's Advanced EFI Tuning book. It will walk you through everything.
    The swap changed my inlet routing, and thus threw off the MAF readings. The LS6 intake increased the Volumetric Efficiency by about 12% at the torque peak, but only about 5% near the redline because the cam was running out of steam. Good thing I just fixed that.... more to come.
    2007 GXP, CAI Intake, 85mm MAF, LS6 Intake Manifold, 42# LS3 Injectors, PRC Ported and Milled 243 Heads - 11:1, 224/232-113+5 Comp Cam, PAC 1218 Springs, DT Headers (w/Custom Crossover Pipe), Cutout and Maxflows, TEP Transmission (3.29s), HP Tuned by Me, Pioneer Speakers and MTX Subs, 13.1 @ 108.7 on street tires at full weight.
  1. Intake manifold
    By rryanwswan69 in forum Turbo
    Last Post: 10-28-2016, 05:29 PM
  2. Corroded LIM Lower intake manifold Get new manifold or is this one ok
    By jj5428 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-16-2015, 07:04 AM
  3. upper intake and lower intake manifold gasket
    By RICKS04GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2014, 12:06 PM
  4. Intake manifold help
    By gr8scott72 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-13-2012, 07:29 AM
  5. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
