Hello and it only happened about a week ago when I let the battery go dead... until then it was running fine, (now ignition switch has messed up in past, if you turn key and gxp shows on display then it started fine but if no gxp showed up on display then it wouldn't even try to turn over and you'd have to cycle key off and back on until gxp showed on display then good to go) but never took more than a couple tries... but now I get gxp on display and still doesn't try to start... it'll click like battery's dead sometimes and you can hear relays clicking on fuse box on passenger fender but still doesn't turn over... and battery's new, starters new and connections all seem good , ohm out ok... so I'm hoping someone's ran into this before... because I'm out of ideas... any help is greatly appreciated!!
Thanks
Jerad
