Thread: Oil leak GXP, thought it was main, but maybe not
Results 1 to 3 of 3
  1. #1 Oil leak GXP, thought it was main, but maybe not
    GT Level Member penright's Avatar
    Mar 2013
    United States
    I was hoping for a second set of eyes. The last 30,000 miles I have had to add some oil and the oil pan is wet. All of this started when I replaced the valve cover gaskets. I wonder if that started holding the blow by more? The car has about 190,000+ miles. When I pull the torque converter access cover, it was completely dry.
    Looking up the side of the block is dry, I don't think it is from the valve cover change out. Could it be from the oil pan gasket? I also heard the fuel pump block plate could be it.
    One other question, how does the oil plug seal fit? Should it fit down in the grove? When I push it down below the threads it wants to pop up. Is this the right one? I had one from a auto parts store before this one that I got online. They both did the same thing? Also, the circular grove at the threads. Is there from years of oil changes and removing and installing the plug?
    I took some picture since they can explain it better than I can. I did wipe everything down and this time I will look before the next oil change. :-)
    07 Grand Prix GXP (My Daily Driver and future toy) (120,000+)
    97 Grand Prix GT (Project Car) (178,000+)
    02 Mustang Convertible (Wife's Toy) (75,000+)
    17 Honda Civic (Wife's Daily Driver)
  2. #2 Re: Oil leak GXP, thought it was main, but maybe not
    Mar 2013
    United States
    The pictures didn't take, not sure what I did wrong. Also, I don't see how to edit.
  3. #3 Re: Oil leak GXP, thought it was main, but maybe not
    Mar 2013
    United States
  1. Has anyone ever used the ARP main studs or Main Cross Bolts?
    By acidcrashdburnd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2013, 10:00 PM
  2. Front Main Oil Leak...How Much Involved?
    By bassamore in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-28-2012, 12:03 AM
  3. main caps
    By redynscire in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2011, 01:11 AM
  4. main cap and rod bolts
    By chev1988rolet in forum Off Topic Discussion
    Last Post: 07-30-2010, 01:46 AM
  5. Main reason for Amp to cut Out
    By jacobmh27 in forum Audio, Security & Visual Electronics
    Last Post: 07-18-2008, 09:57 AM
