Thread: Oil Pressure Issue
Results 1 to 7 of 7
  1. #1 Oil Pressure Issue
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    I got an OBDII message telling me the oil pressure sensor was out, so I replaced it. The code came back last week, and I cleared it.
    Now, apparently, the sensor is working, because I got "Low Oil Pressure" on the DIC. I checked the level, and it was low. Immediately threw in a quart.
    I have never gotten a "Low Oil Level" message, which is one of the reasons I assume the DoD isn't working. Does this masterpiece not HAVE an oil level sensor, just as it can't be bothered to tell me when the DoD is active, or do I have a dead sensor somewhere? If so, approximately where?
  2. #2 Re: Oil Pressure Issue
    Jul 2016
    Brevard County, FL
    Revised situation--I now have TWO oil pressure sensor codes, 0521 and 0522. Has my non-OEM sensor already taken a ****, or is the problem that (despite buying picks for the specific purpose) I couldn't get the screen out to clean it or change it?
  3. #3 Re: Oil Pressure Issue
    bet its the oil pick up tube o ring failure deal. fails where it bolts to the pump. then sucks air. id stop driving it till you figure it out.
  4. #4 Re: Oil Pressure Issue
    Jul 2016
    Brevard County, FL
    It was the O-ring. Thanks for the help!
  5. #5 Re: Oil Pressure Issue
    Non OEM sensors are usually never that good.
  6. #6 Re: Oil Pressure Issue
    Apr 2014
    commerce twp,mi
    ive learned that with quite a few different car makes, aftermarket sensors have a tendency to be this way.
    08 grand prix NA3800
  7. #7 Re: Oil Pressure Issue
    Nov 2019
    WI
    I changed out two of them aftermarket until I finally said fu** it and bought an oem. Been fine since.
  1. Fuel pressure issue?
    By FordMan77 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-20-2018, 01:01 PM
  2. Crazy fuel pressure issue, keep getting stranded
    By Ddk4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2017, 08:17 AM
  3. Coolant pressure issue???
    By Ddk4 in forum General Grand Prix Discussion
    Last Post: 03-27-2017, 06:57 AM
  4. Fuel Pressure Issue
    By SubwayGuy in forum General Grand Prix Discussion
    Last Post: 12-08-2015, 09:04 PM
  5. fuel pressure issue
    By SgtMarshal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-28-2015, 03:55 PM
