Thread: 07 GXP throwing P0327 KNock sensor - Need location
Results 1 to 5 of 5
  1. #1 07 GXP throwing P0327 KNock sensor - Need location
    Oct 2017
    IL
    Can someone help me out telling me where the Sensor 1 bank 1 sensor is located? Cany find anything on internet for it.
    Thank you,
  2. #2 Re: 07 GXP throwing P0327 KNock sensor - Need location
    hangover park IL
    BANK 1 Is always the engine bank with cylinder 1, which is typically the cylinder closest to the front of th eengine.
    sensor 1, would be closest to bank 1.
    B1 S2 would be the ssecond farthest sensor on bank 1, B2S1 would be the closest sensor to bank 2
    lookup your engines cylinder and firing order and youll have no problem
    ~James~ Psychotic Gearhead
  3. #3 Re: 07 GXP throwing P0327 KNock sensor - Need location
    Nov 2019
    WI
    Bank 1 is the left side or front of the engine, as your facing the motor. It is about half way up the block. It has an electrical connector attached to it.
    07 GXP throwing P0327 KNock sensor - Need location Attached Images
  4. #4 Re: 07 GXP throwing P0327 KNock sensor - Need location
    Oct 2017
    IL
    the one they matches your picture location looks different than the sensor they sold me. Below is a link of the one they sold me. Do you know a part number for the old I need then?
    Access Denied
  5. #5 Re: 07 GXP throwing P0327 KNock sensor - Need location
    Nov 2019
    WI
    12623730 Is the GM part number. Your pic looks right btw.
  1. Daughter-in-Laws GP throwing O2 sensor code
    By BasilFawlty in forum Engine
    Last Post: 12-16-2019, 08:45 PM
  2. False knock causing p0327?
    By outonthetiles in forum General Tech Discussion
    Last Post: 05-18-2012, 03:16 PM
  3. Changed o2 sensor and Still throwing out same codes!?????
    By johnnyb in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-18-2011, 04:16 PM
  4. knock sensor location?
    By quickster in forum General Tech Discussion
    Last Post: 03-22-2011, 12:10 AM
  5. Knock Sensors Location 3800
    By MDThomas26 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-01-2010, 12:23 PM
