Thread: Strange Engine Problem
Results 1 to 9 of 9
  1. #1 Strange Engine Problem
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    I've never had something like this happen before. Occasionally the stereo will get very loud for a second, the speedometer will fluctuate. and then the engine will shut off. Sometimes the first two things will happen and the engine keeps running, but is sluggish for a few seconds.
    Any ideas?
  2. #2 Re: Strange Engine Problem
    Apr 2014
    commerce twp,mi
    check your grounds and power supply wires at the bat and alt.
    whats the condition of your battery?
    08 grand prix NA3800
  3. Likes Hurricane87 liked this post
  4. #3 Re: Strange Engine Problem
    Dec 2013
    Enfield
    Maybe the vehicle speed sensor? I believe the radio is connected to that.
  5. #4 Re: Strange Engine Problem
    Jul 2016
    Brevard County, FL
    Tightening the battery terminals made it better, but didn't eliminate it. I just noticed today that the fluctuations in the HUD (which had earlier been repaired under warranty by a software update) go along with the speedo fluctuations, so I'm thinking it may be the speed sensor.
  6. #5 Re: Strange Engine Problem
    Wichita
    Ooh I had a similar problem happen. For sure check that vehicle speed sensor, your grounds and check from exposed wiring.
  7. #6 Re: Strange Engine Problem
    Wichita
    ^^^because 1 or more of those 3 things will be the problem.
  8. #7 Re: Strange Engine Problem
    Jul 2016
    Brevard County, FL
    Changing the vehicle speed sensor made it worse--now the cruise control shuts itself off.
    The battery terminals have also been changed. Anyone have any other ideas? Please don't say "grounds." It's a Florida car that started its life in Oklahoma. Nothing is rusted out.
  9. #8 Re: Strange Engine Problem
    Dec 2013
    Enfield
    If it got worse changing the sensor you may have a bad one, it shouldn't have gotten worse. Wire corrosion can happen over time and these cars are old, regardless where the car has been. CRC makes a battery cleaner and also a protector, if you spray it on the grounds it will strip off any corrosion. Cheap enough to try. Also make sure the power junction box with the cover by the passenger strut tower is tight , these can cause funky things to happen when they loosen. Keep at it, you will get there. good luck.
  10. #9 Re: Strange Engine Problem
    Wichita
    ^^^I second that. Take the new sensor back and exchange it for another one. I know it sucks to have to do that. Especially with that sensor.
  1. Strange Engine Problem
    By Hurricane87 in forum General Grand Prix Discussion
    Last Post: 11-08-2019, 10:28 PM
  2. Strange problem......
    By Spike89 in forum Audio, Security & Visual Electronics
    Last Post: 12-20-2012, 12:22 AM
  3. strange problem
    By LSXHP in forum General Tech Discussion
    Last Post: 01-15-2011, 01:35 AM
  4. Strange transmission problem
    By fishman517 in forum General Tech Discussion
    Last Post: 11-18-2010, 06:20 PM
  5. very strange problem.
    By maniakmyke in forum General Tech Discussion
    Last Post: 03-04-2010, 04:45 AM
