Thread: engine code P0300
Results 1 to 4 of 4
  1. #1 engine code P0300
    Kemmerer, Wyoming
    when I started my car this morning, the check engine light started flashing at me. so I got my scanner out and checked the code. The dreaded P0300 came up. are there any common failures that cause this? dod is already disabled and has been for some time. plugs and wires were done like a year ago.
  2. #2 Re: engine code P0300
    P0300 just means it's more than one specific cylinder. So using the live data scanner you have to watch all cylindera at once to see what ones are doing it the most.
    AFM/DoD can be disabled but that doesn't mean the lifters aren't going to still cause problems. Without knowing what cylinders are causing the code it hard to comment on what the issue is.
  3. #3 Re: engine code P0300
    Apr 2015
    Columbus, OH
    Sh1t. Must be something in the air dude. Same thing happening to me. I've got 0300 and 0306. Check the scanner and look at the cylinder counts. Mine are mostly on 6 but I see a few misfires add up on a couple cylinders. I'm gonna do a compression check tomorrow but I have that bad feeling it's a mechanical issue. Hope you just have a bad coil or something.
    Top Swapped 01 Imp
  4. #4 Re: engine code P0300
    GTP Level Member
    Oct 2014
    Just had the same thing. Turned out to be a bad coil pack.
  1. Need help with a P0300 code
    By derpyimp in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-04-2018, 03:18 PM
  2. Engine code p0304 and p0300
    By Aaron85 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-01-2017, 08:14 AM
  3. P0300 code , need help !!
    By damohr in forum General Tech Discussion
    Last Post: 03-04-2015, 07:44 PM
  4. someone help? p0300 code
    By ericg1181 in forum General Tech Discussion
    Last Post: 04-07-2014, 02:09 PM
  5. Check engine code: P0300?
    By CSteen85 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-02-2010, 11:45 AM
