Thread: Starter just clicks won't spin
Results 1 to 6 of 6
  1. #1 Starter just clicks won't spin
    Donating User
    Aug 2016
    MI
    I just put a new starter on, and when I try to start the car it just clicks. I verified the battery is good and everything is hooked up. Not really sure what to do.
  2. #2 Re: Starter just clicks won't spin
    where do you hear the click from? inside the dash? if so thats the sound of a bad starter. you can try to jump it with a screw driver see if it will crank it over.
    you got all the wires back on right? small wire needs to be on the small stud, pos cable and the other wire with a fat eyelet go on the fat stud that the pos cable goes to.
  3. #3 Re: Starter just clicks won't spin
    Donating User
    Aug 2016
    MI
    The starter itself is clicking. I'll double check my wiring real quick.
  4. #4 Re: Starter just clicks won't spin
    makes sure the battery terminals are clean and tight too. bad ground can cause this as well.
    they put two small studs on the v8 starter? might have the small wire on the wrong stud?
  5. #5 Re: Starter just clicks won't spin
    Donating User
    Aug 2016
    MI
    Well I unhooked the starter wires and hooked em back up and its working now. I'm not sure what the issue was exactly.
  6. #6 Re: Starter just clicks won't spin
    odd but thats good. maybe a wire eyelet was dirty and it cleaned its self when you took it back off or back on?
  1. Keep stock starter set up and add 4 gauge hot wire to starter
    By Jason97GrandprixGT in forum Audio, Security & Visual Electronics
    Last Post: 04-08-2015, 08:21 AM
  2. Remote Starter not working, just clicks.
    By brenglen in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-26-2014, 06:11 PM
  3. Took a spin in the Deville
    Last Post: 04-28-2011, 11:44 PM
  4. Did i spin a bearing or am I safe?
    By Fyrechikin in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-01-2010, 08:21 PM
  5. no reverse, clicks in P & N, works in 1st
    By elsolo in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-19-2009, 11:49 AM
