Thread: LS4 Build, what to buy?
Page 3 of 8 FirstFirst 12345 ... LastLast
Results 41 to 60 of 143
  1. #41 Re: LS4 Build, what to buy?
    Kemmerer, Wyoming
    I would do a search for someone local. You might be able to get an overkill tune done, but don't expect it to be dead on out of the box.
  2. #42 Re: LS4 Build, what to buy?
    Donating User
    Aug 2016
    MI
    The new used engine showed up yestarday, it has about 125,000 miles on it. The spare block will probably be used for a fiero swap project later on.
    I also managed to get the engine bay repainted. there was rust around the battery tray area, and my battery tray is in peices.
    Also a few other odds and ends showed up in the mail ,new wheels from american racing, new zzp downpipe, and timing chain from katech.
    The old motor mount was also shot, which explains the cluncking noise i would hear sometimes.
    Not much left now and ill be ready to start reassembly.
    LS4 Build, what to buy? Attached Images
  3. #43 Re: LS4 Build, what to buy?
    The Boss Iceman6669's Avatar
    Jun 2011
    Looks good!
    2011 F-150 Yote powered
  4. #44 Re: LS4 Build, what to buy?
    Donating User
    Aug 2016
    MI
    Thanks. It will be nice to get it out of the garage soon.
  5. #45 Re: LS4 Build, what to buy?
    Donating User
    Aug 2016
    MI
    The last two boxes finally arrived. The dod delete,and cam kit from Texas Speed. And the headers from doug thorley.
    I still need to buy a new oil pump, im open to suggestions on a replacement. now its time to get the heads cleaned and rebuilt.
  6. #46 Re: LS4 Build, what to buy?
    A new stock oil pump is just fine. High volume pumps in 90% of vehicles are useless because you aren't going to be flogging it at 5,000-6,000+ rpm all day everyday where the extra flow may be wanted for extended periods of time. Or if you were running a stroker with increased bearings clearances that require more oil flow at all times.
    Just the AFM/DoD delete alone should bump oil pressure by at least 5-10psi on it's own. Being that this is a GEN 4 engine it's likely to have a oil pressure relief valve on the oil pan or somewhere on the engine block but I'm not sure what the LS4 pan looks like off the engine. If you remove that relief valve that is there for the AFM/DoD system you gain another 5-10psi at idle and it will cruise at 45-50psi instead of 35-40psi. Then it will go higher than 40-50psi at WOT to 55-65psi in most cases. These are the results all the truck guys get when they do these changes.
    Here is a LS3 pan with the valve and the trucks look the same way, replace it with a plug.
  7. #47 Re: LS4 Build, what to buy?
    Kemmerer, Wyoming
    I'm excited to hear how it goes when it's back on the road.
  8. Likes 05GXPBeast liked this post
  9. #48 Re: LS4 Build, what to buy?
    Donating User
    Aug 2016
    MI
    Wont be long now. I got the new cam put in this weekend. Ill be getting the heads back sometime this week and ill be ready to put the motor back in.
    I decided to paint the valve covers since i didnt have the heads back yet.
  10. #49 Re: LS4 Build, what to buy?
    Donating User
    Aug 2016
    MI
    I am also putting together a custom intake setup. Im running an ls6 intake with an ls2 throttle body, but ive heard that I might have clearance issues with the doug thorley headers. Im following a thread written by DavidGXP, But im having trouble finding a throttle body adapter. Does anybody on the Forum know someone who makes custom adapters? help with this would be greatly appreciated.
  11. #50 Re: LS4 Build, what to buy?
    Dec 2013
    Enfield
    There are lots of adapters on eBay, I would check there. I am not sure, bit this looks right I think. I don't have this so double check before buying anything. Build looks good!
    Universal Manifold Adapter Plate For 92MM 3.6" THROTTLE BODY LS1 LS2 LS6 LSX LS4 | eBay
  12. #51 Re: LS4 Build, what to buy?
    Donating User
    Aug 2016
    MI
    I got my ls2 throttle body today along with the 6 pin connector. Special thanks to 91parkave for his thread on ls1tech, it made it super easy to rewire the connector.
    LS2 GTO TB . LS4 TB
    PIN A ---- PIN F
    PIN B ---- PIN E
    PIN C ---- PIN H
    PIN D ---- PIN A
    PIN E ---- PIN B
    PIN F ---- PIN D
  13. #52 Re: LS4 Build, what to buy?
    Donating User
    Aug 2016
    MI
    I cut my alt. bracket to make room for the ls6 intake. Still waiting to get the heads back.
    I also put the downpipe on in the meantime.
  14. #53 Re: LS4 Build, what to buy?
    Jun 2011
    You should do show to write-up type thread on both of those mods! I’m sure someone else out there will wanna do it at some point.
  15. Likes 05GXPBeast liked this post
  16. #54 Re: LS4 Build, what to buy?
    Donating User
    Aug 2016
    MI
    once I get everything together and figured out I can go over a detailed list of what I bought and what I had to do to make it work. I think i got everything figured out except the vaccum fittings on the intake and throttle body. The ls2 TB doesnt have the vaccum fitting like the ls4 TB.
  17. #55 Re: LS4 Build, what to buy?
    Donating User
    Aug 2016
    MI
    Im 99% sure that the throttle body adapter that I bought wont work with my doug thorley crossover pipe. So I designed an adapter, and im gonna try contacting katech to see if they can help me get one made. Its just a rough draft but hopefully they can help me fill in the blanks.
  18. Likes Iceman6669 liked this post
  19. #56 Re: LS4 Build, what to buy?
    Jun 2011
    Looks pretty slick
  20. #57 Re: LS4 Build, what to buy?
    Donating User
    Aug 2016
    MI
    I sent an email to jason at Katech. Hopefully ill have some good news for anyone who would be interested in buying one. As far as i know there is no other options.
  21. #58 Re: LS4 Build, what to buy?
    Mar 2014
    Tucson
    If you're interested, I could take a closer look at the design to help minimize the cost to manufacture.
    Also, it's probably going to be a lot cheaper to go to a mom and pop type machine shop. A place that specializes on one-off pieces. Katech (and the like) run production. You'd be paying for your piece and all the pieces they didn't make while they were cutting yours.
  22. Likes 05GXPBeast liked this post
  23. #59 Re: LS4 Build, what to buy?
    Donating User
    Aug 2016
    MI
    Absolutely. I can email you a step file if you'd like. Its a very rough draft, and i wasnt even sure where to put the screw locations.
  24. #60 Re: LS4 Build, what to buy?
    Mar 2014
    Tucson
    Can you transfer the screw locations with a center punch then hand drill & tap, or would they NEED to be put in on the machine?
    You should be able to find the screw locations if you look hard enough or know where to look.
    Shoot me a PM with your email and the specifics of what your wanting to do. Like, what throttle body to what intake and any other pertinent details.
  25. Likes Iceman6669 liked this post
  1. Replies: 399
    Last Post: 08-17-2016, 01:35 PM
  2. '95 GTP Build
    By PixelTwister in forum Introductions/Noob Questions
    Last Post: 08-08-2015, 05:01 PM
  3. Build all you can build S/C 3800
    By MrPhotographer06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-30-2013, 12:01 AM
  4. Too Slow, Time for a build (GEN V/N*/L32 Lim build)
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2012, 01:54 PM
  5. My Build
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 10-30-2010, 04:24 PM
