Thread: 07 Grand Prix GXP - Overheating Issue at Idle and Above 85F with A/C
Results 1 to 5 of 5
  1. #1 Re: 07 Grand Prix GXP - Overheating Issue at Idle and Above 85F with A/C
    Quote Originally Posted by cheatah faheatah View Post
    A short term/quick fix to get you through this heat, I would suggest removing the thermostat so you get continuous coolant flow. I'm not familiar w/ 8 cyl setups but if your a/c condenser is in front of your rad,(like all cars I've seen) might it be clogged w/debris? or have a buncha bent over fins which would block your airflow? Also some fans are reversible, might they be spinning backwards ? that's my $0.02............ good luck, let us know howya makeout........E.
    As previously stated no.
    And I'm with 91parkave, my old black car did the same thing, when the temp was 85+ and the ac was in sitting in traffic the temp gauge would just climb up but as soon as you started moving it dropped right down. Only one of my fans was kicking in.
  1. 2002 Grand Prix GT 3.8 Idle Issue
    By Der2z in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2016, 09:15 AM
  2. Throttle Body to vacuum line connector '99 Grand Prix (Also, erratic idle issue)
    By killswitch83 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-05-2012, 05:52 PM
  3. 1994 Pontiac Grand Prix - Overheating Issue - No fans?
    By extreme in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-18-2012, 02:57 AM
  4. Overheating Grand Prix
    By mhartwig in forum General Tech Discussion
    Last Post: 11-02-2010, 11:14 AM
  5. 96 grand prix overheating issue
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-10-2009, 12:37 AM
