Thread: Range active fuel management disable device
Results 41 to 60 of 89
  1. #1 Re: Range active fuel management disable device
    It's all about correct exhaust velocity.
    Just because you have 2.5" or 3.5" doesn't mean it's going to:
    A) Choke the car out
    or
    B) Gains stupid amounts of power.
    Backpressure is laughable and so is the debate about gaining power on a 275~ WHP LS4 car going from 2.5" to 3" is funny as well.
  2. #2 Re: Range active fuel management disable device
    Dec 2013
    Enfield
    Good thing you were here to let us all know.
  3. #3 Re: Range active fuel management disable device
    Oh no problem skipper.
    I'll be here tomorrow, too.
  4. #4 Re: Range active fuel management disable device
    Dec 2013
    Enfield
    Looking forward to more wisdom, Gilligan.
  5. #5 Re: Range active fuel management disable device
    Jan 2016
    Dayton
    Ok. So back to the dod delete. What's the best way other than the Diablo tune. I don't care about a tune honestly just want to get rid of it without tearing the motor apart
  6. #6 Re: Range active fuel management disable device
    Quote Originally Posted by rottonj View Post
    Be sure to keep yourself on that island, Ginger.
    Don't need you venturing away and hurting yourself with that knowledge base.
    Quote Originally Posted by Mosley9423 View Post
    Tune it out.
    Get someone to do it and quit beating around the bush on it. Do it right or don't bother.
  7. #7 Re: Range active fuel management disable device
    Dec 2013
    Enfield
    Quote Originally Posted by blueguy View Post
    All good, we are not helping much with this.
  8. #8 Re: Range active fuel management disable device
    Dec 2013
    Enfield
    You never said what your mileage is. How much oil is the vehicle burning between changes? Tuning out DOD isn't a cure all for a engine with bad valve seals or rings.
  9. #9 Re: Range active fuel management disable device
    Jan 2016
    Dayton
    I'm honestly not sure on how much oil it's burning. My car has 130k I just bought it a week ago. I just want the dod gone because it sounds terrible with the exhaust on it. It sounds like I'm driving a helicopter down the highway and from what I was reading it just helps The car from burning oil.
  10. #10 Re: Range active fuel management disable device
    Dec 2013
    Enfield
    Unless you already have a tuner or HP tune access this wont be cheap just to get rid of that noise. Do what you want, but if it was me it would be much cheaper to add a resonator or different mufflers. My exhaust is stock, and while I can tell when it enters 4 cylinder mode it is not annoying at all.
  11. #11 Re: Range active fuel management disable device
    Jan 2016
    Dayton
    Well from what I read it helped with the oil burning. Not sure if this car does or not but after driving it you can smell it so I just want to help prevent anything I can
  12. #12 Re: Range active fuel management disable device
    Dec 2013
    Enfield
    Lots of info on it. I don't have it tuned out, but mine doesn't use any oil between changes either. Good info here. Do some searching.
    http://ls1tech.com/forums/ls4-performance-108/
  13. #13 Re: Range active fuel management disable device
    A bigger reason to disable it, is because the lifters are prone to failure. The less they are active, hopefully the longer they last.
  14. #14 Re: Range active fuel management disable device
    Jan 2016
    Dayton
    What's a reasonable tuner I can buy to get rid of it that won't cost me an arm and a leg
  15. #15 Re: Range active fuel management disable device
    Dec 2013
    Enfield
    Do some searches. You just got the car, don't blow your whole wad getting rid of an annoying exhaust note. Chances are if the transmission isn't gone thru already you will have to spend money there, and that wont be cheap.
  16. #16 Re: Range active fuel management disable device
    Jan 2016
    Dayton
    I think someone has already done work to the trans
  17. #17 Re: Range active fuel management disable device
    Apr 2015
    NJ
    Diablo tune is the cheaper solution, hptuners is the CORRECT solution.
  18. #18 Re: Range active fuel management disable device
    Arizona
    Overkill pcm would be a better option than diablo
  19. #19 Re: Range active fuel management disable device
    Jan 2016
    Dayton
    Range active fuel management disable device Attached Images
  20. #20 Re: Range active fuel management disable device
    So Cal
    Quote Originally Posted by 91parkave View Post
    I just sent my computers up to Overkill in Canada. I paid $180 for the "send in special". I had to pay $40 to ship my computers to him and the $180 for tuning and return shipping. My car runs and shifts WAY better now. I had DOD turned off completely. He also turned off or turned down the stabilitrak system so I can burnout going around a corner now without the damn computer limiting the power and making the car bog out. This Overkill tune just woke my car up. It seems a little more powerful now. The trans shifts WAY better too. You can also rev it past 4000 RPM in park too unlike the stock tune. It just makes the whole driving experience of my car better. It was worth the $220 FOR SURE.
    http://www.getoverkilled.ca/LS4.html
  1. Bad to disable torque management?
    By 97AutoXVette in forum PCM Tuning
    Last Post: 03-17-2017, 04:38 PM
  2. Anyone added fuel capacity for extra range?
    By bobc455 in forum 04+ Specifics
    Last Post: 03-09-2015, 10:45 AM
  3. Torque management
    By apierce1289 in forum PCM Tuning
    Last Post: 06-02-2013, 12:43 PM
  4. Low range ding sound disable?
    By aeidian in forum Audio, Security & Visual Electronics
    Last Post: 05-06-2013, 09:51 AM
  5. Torque management What is it?
    By JoshsGTP in forum General Tech Discussion
    Last Post: 06-27-2010, 08:21 AM
