Thread: Bank 1 to lean & cylinder 6 misfire
Results 1 to 20 of 23
  1. #1 Bank 1 to lean & cylinder 6 misfire
    GT Level Member xxburkettxx07's Avatar
    Topeka, ks
    98gtp keep getting the to lean code and cylinder 6 misfire, in getting spark, new plugs, n wires. Short term fuel trims are 23 26 I believe. Should be -8 correct? Could this be a gasket or injector.the miss fire is kind of a very small stutter at idle only car runs great through out driving...
    Sent from my SAMSUNG-SM-G870A using Tapatalk
  2. #2 Re: Bank 1 to lean & cylinder 6 misfire
    Short terms trims will always bounce around, there is no set number because they do whatever is needed to bring fuel in or take it away.
    But if they are always high, then thats a issue. You will want to look at your long term trims more here, if they are stuck at +16.4, then you have a vacuum leak and that can be the cause of your misfire.
  3. #3 Re: Bank 1 to lean & cylinder 6 misfire
    Topeka, ks
    Ok long term fuel trims are stuck 16.4
  4. #4 Re: Bank 1 to lean & cylinder 6 misfire
    Topeka, ks
    I can't find a vacuum leak. CAR runs fine its when it's idiling, it's idling a lil fast with a very very small stutter to it almost can't tell it is unless you're really listening to it.
  5. #5 Re: Bank 1 to lean & cylinder 6 misfire
    I assume you can watch the fuel trims as you run the car right?
    I would spray whatever you got be it brake cleaner or throttle body cleaner around while you watch the trims, when they change you can narrow down the spot of the leak.
    Wouldnt hurt to remove the fuel rail and inspect the injector o-rings too, thats simple enough and narrows down a possible cause.
  6. #6 Re: Bank 1 to lean & cylinder 6 misfire
    Topeka, ks
    On I sprayed carb cleaner around and think it's the egr valve gasket. I got one only a buck not sure if it's it but it was cheap
  7. #7 Re: Bank 1 to lean & cylinder 6 misfire
    Topeka, ks
    I did a vacuum leak check with smoke noticed my egr stove pipe is leaking going from egr to intake is therea gasket that goes in there? Or just a bad pipe
  8. #8 Re: Bank 1 to lean & cylinder 6 misfire
    you could try some rtv. un bolt it rtv it, bolt it back on. dont pull the tube out. the flange part comes free, rtv that, or around the tube in the intake.
  9. #9 Re: Bank 1 to lean & cylinder 6 misfire
    Topeka, ks
    That's what I was thinking good ol rtv
  10. #10 Re: Bank 1 to lean & cylinder 6 misfire
    the tubes do split, so make sure its not cracked. theres a seam along its whole length.
  11. #11 Re: Bank 1 to lean & cylinder 6 misfire
    Topeka, ks
    Ok I'll check, I hope this takes care both my issues
  12. #12 Re: Bank 1 to lean & cylinder 6 misfire
    hangover park IL
    Quote Originally Posted by WileyCoyote View Post
    this, though its usually hidden in the corrugated recess' (valleys)
    ~James~ Psychotic Gearhead
  13. #13 Re: Bank 1 to lean & cylinder 6 misfire
    Topeka, ks
    Mine had crack under the flange I
    Used red high heat rtv waitin for it to dry now
  14. #14 Re: Bank 1 to lean & cylinder 6 misfire
    Topeka, ks
    Still no better still have the lean code rough idle nothing has changed
  15. #15 Re: Bank 1 to lean & cylinder 6 misfire
    Topeka, ks
    Before I got the lean code and cylinder-6 misfire I had a evap code can't remember which one but I no longer get an evap code just the lean code which is causing a misfire...
  16. #16 Re: Bank 1 to lean & cylinder 6 misfire
    Topeka, ks
    I do believe I find the culprit..Supercharger gasket..I wad spraying brake cleaner n pow sure it's my problem I just replaced it 8 months ago can't believe it's bad already
  17. #17 Re: Bank 1 to lean & cylinder 6 misfire
    I was going to say just remove the egr system completely.
  18. #18 Re: Bank 1 to lean & cylinder 6 misfire
    what brand gasket? garleaks are the worst if thats what you got. felpro seem to be pretty good, used then 2 times now with no leaks at all.
  19. #19 Re: Bank 1 to lean & cylinder 6 misfire
    Topeka, ks
    I have agarlock n going with felpro now
  20. #20 Re: Bank 1 to lean & cylinder 6 misfire
    Topeka, ks
    Can I remove the egr n block it off completely with out needing a tune?
  1. Running lean on bank 1
    By nathnn99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2015, 12:06 PM
  2. Po170 Po300 Po560 system too lean , random cylinder misfire and iac rpm idle higher
    By mpiacc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-26-2013, 11:34 AM
  3. Codes P0171 Lean Bank One
    By Garry in forum General Tech Discussion
    Last Post: 02-07-2013, 05:10 PM
  4. #4 misfire during boost, also bank 1 lean
    By petebjork in forum Introductions/Noob Questions
    Last Post: 06-01-2012, 11:44 PM
  5. Running lean in one bank?
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-15-2010, 01:22 PM
