Thread: Bank 1 to lean & cylinder 6 misfire
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #1 Re: Bank 1 to lean & cylinder 6 misfire
    change that gasket. they suck so bad.
  2. #2 Re: Bank 1 to lean & cylinder 6 misfire
    GT Level Member xxburkettxx07's Avatar
    Topeka, ks
    Yea I was just reading the reviews on zzp more bad than good .would an oe gasket be better or just sick with felpro
    Sent from my SAMSUNG-SM-G870A using Tapatalk
  3. #3 Re: Bank 1 to lean & cylinder 6 misfire
    Oct 2015
    Northville michigan
    I'm having the same issue. Did it end up being the s/c gasket?
  1. Running lean on bank 1
    By nathnn99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2015, 12:06 PM
  2. Po170 Po300 Po560 system too lean , random cylinder misfire and iac rpm idle higher
    By mpiacc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-26-2013, 11:34 AM
  3. Codes P0171 Lean Bank One
    By Garry in forum General Tech Discussion
    Last Post: 02-07-2013, 05:10 PM
  4. #4 misfire during boost, also bank 1 lean
    By petebjork in forum Introductions/Noob Questions
    Last Post: 06-01-2012, 11:44 PM
  5. Running lean in one bank?
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-15-2010, 01:22 PM
