Thread: Cylinder 1 ignition signal wire
Results 1 to 5 of 5
  1. #1 Cylinder 1 ignition signal wire
    GT Level Member jdmgtp's Avatar
    MI
    I bought a knock monitoring device I want to hook up for knock per cylinder and I need to hook into the signal wire for cylinder 1. I know it's in the group of wires that plug into the ICM under the coils but IDK which one it is. Anybody point me in the right direction?
    2000 GTP, 3.2 pulley, SD headers, 3" exhaust, modded 1.9's, custom CAI, LS6 maf, ported blower/ TB, HPT, 65 lb injectors, E85 in the summer, LM-1 wideband, 180 stat, autolite 104's, GMHD suspension kit. 13.2@104 on street tires w/o ported s/c
  2. #2 Re: Cylinder 1 ignition signal wire
    Feb 2013
    37.295091, -121.930053
    dude you have 2 knock sensors that detect knock when its running. when it detects a hard enough knock it throws a code. why do you need to redesign what they thought up?
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Cylinder 1 ignition signal wire
    MI
    thanks for the tip. any clue which one is the signal wire?
  4. #4 Re: Cylinder 1 ignition signal wire
    MI
    Ok, I shouldn't even have to explain this but I guess I will anyway. Some vehicles have over active knock sensors and some don't work at all. The unit I have allows for accurate calibration of the factory knock sensors along with knock per cylinder which however isn't possible on the 3800's since they use a waste type ignition but at least I will be able to see by pairs. I will use this mostly for high hp force induction ls engines but thought it would be fun to hook up to my beater. After you've tuned as many 1000+hp engines as I have then you can school me on why I need these.
  5. #5 Re: Cylinder 1 ignition signal wire
    MI
    nevermind I found my answer.
  1. 00 ignition cylinder issue
    By johnnieh06 in forum General Grand Prix Discussion
    Last Post: 08-15-2014, 09:12 AM
  2. ignition lock cylinder inquiry
    By kidscar2004 in forum General Tech Discussion
    Last Post: 07-09-2012, 06:41 AM
  3. tach signal wire behind the dash?
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 06-28-2012, 08:24 AM
  4. replaced bcm and ignition cylinder and NEED HELP
    By bkatrenak in forum Audio, Security & Visual Electronics
    Last Post: 03-11-2011, 05:08 PM
  5. ignition switch cylinder
    By mtz956 in forum General Tech Discussion
    Last Post: 08-29-2010, 02:21 AM
