Thread: MAF Upgrade?
Results 1 to 11 of 11
  1. #1 Re: MAF Upgrade?
    Quote Originally Posted by 97gtp01gt99gt View Post
    What's outflow
    when you out flow the limits of the maf sensor. to do so you need a turbo, or cam ic heads, aka lots of mods done to out flow the stock maf.
  2. #2 Re: MAF Upgrade?
    Banned
    May 2008
    VA (was NY, MI, MN, FL)
    In even simpler terms, you're going past the highest values on the MAF table in your PCM, which is maxed out at 11,500 hz in the sensor output and 511g/sec in the table. An AFC can be used to skew down the Hz value from the sensor (or a larger diameter MAF tube). If you're getting near or above 511 g/sec, you'll need to skew your injector flow rate down to avoid hitting that value.
    I've dealt with both of these issues, either with 20+psi turbo settings, M90 pulleys in the 2.55-2.70" range, and my MP112 setup. I've been doing both the AFC and Injector skew for a while, to avoid approaching either again.
  1. upgrade
    By CLTACKETT in forum Introductions/Noob Questions
    Last Post: 04-01-2013, 07:09 PM
  2. Headlight and FogLight Upgrade (to upgrade to HID or not?) Please Help???
    By Michigan04GrandPrix in forum Visual/Body Modifications
    Last Post: 04-20-2012, 12:53 PM
  3. PCM Upgrade
    By Vlad0691 in forum General Tech Discussion
    Last Post: 11-26-2010, 12:34 AM
  4. First upgrade for GTP ?
    By MikeZirpola in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-20-2009, 08:20 PM
  5. L26 upgrade
    By tod1d in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-27-2009, 12:33 PM
