Thread: Supercharger gasket
Results 1 to 9 of 9
  1. #1 Supercharger gasket
    GT Level Member xxburkettxx07's Avatar
    Topeka, ks
    I do believe my supercharger gasket is bad I just replaced it 8 months ago it was one of the garlock green ones, do what's a good one I can get that won't fail so early?
    Sent from my SAMSUNG-SM-G870A using Tapatalk
  2. #2 Re: Supercharger gasket
    Buffalo
    A stock GM one
    what troubles are you having that makes you want a new super charger gasket?
  3. #3 Re: Supercharger gasket
    Topeka, ks
    Been having a lean code and misfire sprayed some carb cleaner on it is leaking under throttle body already what's a gm gasket run
  4. #4 Re: Supercharger gasket
    Buffalo
    Never had a garloc leak but I also use RightStuff by Permatex. Dealer could sell you OEM gasket. Zzp and rockauto has felpro for $10 or so.
    Assuming you're using garloc because you are inter cooled, then a stock gasket wouldn't be ideal. What you have now is ideal but you need to seal it up better ; torque it correctly or both
    Last edited by CrazyGuy03; 09-30-2015 at 07:43 AM. Reason: Deal-dealer spelling edit
  5. #5 Re: Supercharger gasket
    Quote Originally Posted by xxburkettxx07 View Post
    When you put a new one on.. take a look at your Garleak and see how it's cut. ZZP isn't known for quality and often their gaskets don't have much material to seal an edge if at all.
  6. #6 Re: Supercharger gasket
    Topeka, ks
    Ok
  7. #7 Re: Supercharger gasket
    Topeka, ks
    Inside of my supercharger it's all black n nasty us brake parts cleaner ok to to clean it out with?
  8. #8 Re: Supercharger gasket
    Buffalo
    I don't see your car year make model etc or a mod list to help you. But I would say NO don't spray anything on the SC rotors
  9. #9 Re: Supercharger gasket
    DO NOT CLEAN IT. That nasty stuff is helping it seal better and work better.
    If you want to strip the rotor coating, I do suggest CRC TB cleaner as I have tested it works rather fast to eff up a charger.
  1. supercharger gasket?
    By Jtg1551 in forum General Grand Prix Discussion
    Last Post: 04-10-2013, 12:07 PM
  2. bad supercharger gasket?
    By scotty455 in forum General Tech Discussion
    Last Post: 03-22-2012, 09:47 AM
  3. Supercharger Gasket
    By RideMr2 in forum General Grand Prix Discussion
    Last Post: 01-29-2012, 02:12 PM
  4. Supercharger gasket
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2011, 03:48 PM
  5. Supercharger Gasket
    By Spazztic2003 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-17-2010, 02:47 PM
