Thread: Oil Leak, What to do to fix?
Results 1 to 20 of 24
  1. #1 Oil Leak, What to do to fix?
    GTP Level Member Kaiser Pontiac's Avatar
    Jun 2015
    Land of 10,000 Salted Roads and Rusty Cars.
    So, I'm working on changing my valve cover gaskets and with some of the stuff off I could see a bit better...
    Wondering what I got leaking there and what it takes to fix it? I get oil under the car if it sits for a few days, I knew the VC gaskets were leaking and probably something else, figured while I got stuff apart should fix any other leaky spots.
    06 LaCrosse 57-79k sold;99 4dr GTP 134-138k sold;98 2dr GTP 183k parted;98 Regal 166-184k;04 GT2 204-206k sold;04 GTP 170-175k sold;09.5 G8 GT Sport 145k;09 G8 78-84k+;08 Prix 164k sold;06 Prix 168k sold;02 Regal 92k;09 G8 103k parted;04 GTP SpEd 139k parted;04 GTP 205k;'09 G8 105k parted;06 Prix 230k;04 CompG 138k
  2. #2 Re: Oil Leak, What to do to fix?
    Kemmerer, Wyoming
    you need to change your coolant elbows and probably your intake manifold gaskets. get the aluminium coolant elbows and the metal manifold gaskets.
    probably should change the valve cover grommets since you are changing your valve cover gaskets.
  3. #3 Re: Oil Leak, What to do to fix?
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Sarge nailed it right on the head. Replace your LIM gasket.
  4. #4 Re: Oil Leak, What to do to fix?
    He already has metal intake gaskets, you guys must be blind.
  5. #5 Re: Oil Leak, What to do to fix?
    Soak the spots in some purple power or whatever you wish and clean the spots off, then drive it for a few days and see if it's really leaking or just a super minor seep thats taken forever to build up to that point.
  6. #6 Re: Oil Leak, What to do to fix?
    that elbow is soaking wet. 10 bucks and its fixed.
    looks like silver gaskets to me too. but could be the flash or the lighting.
  7. #7 Re: Oil Leak, What to do to fix?
    Apr 2015
    Well he'll have to change the little rubber side pieces anyway so he'll have to take everything apart anyway. Do they sell those side gaskets separate?
  8. #8 Re: Oil Leak, What to do to fix?
    Quote Originally Posted by SubwayGirl View Post
    wtf are you talking about now?
  9. #9 Re: Oil Leak, What to do to fix?
    Kemmerer, Wyoming
    I couldn't tell for sure if it had the metal intake manifold gaskets, that's why I said probably.
  10. #10 Re: Oil Leak, What to do to fix?
    Apr 2015
    Quote Originally Posted by ScottyDoggs View Post
    Those blue side gaskets that seal the gap between the two heads. You apply 4 dabs of RTV without them, and them 4 more dabs with them on. Those things. That's only thing that would cause it to leak oil from the LIM.
    They are orange from the factory.
  11. #11 Re: Oil Leak, What to do to fix?
    i knew what you meant, and wrong....... the possibility of it leaking oil from the rubbers is so slim to none. and the upgraded gasket kits come with blue and orange side rubbers, you use what ever one works for you. orange has locating pins, blue does not.
  12. #12 Re: Oil Leak, What to do to fix?
    Apr 2015
    My blue ones had the locating tabs. And yes, the probability of those side gaskets leaking is very slim unless someone didn't use enough RTV. But that is the only place on the LIM oil can escape from. Unlikely, but possible. Unless there is somewhere else that causes it to look that way.
  13. #13 Re: Oil Leak, What to do to fix?
    arrrgghhhhhh........please do your best to tell me how oils gonna leak out the rubber....please, entertain me more....
  14. #14 Re: Oil Leak, What to do to fix?
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    I get the feeling Scotty is being semi-trolled
  15. #15 Re: Oil Leak, What to do to fix?
    not at all, he dont know a whole lot yet.
    technically i think i was trolling him at the end lol
  16. #16 Re: Oil Leak, What to do to fix?
    Let's clear this up.
    The coolant elblow is leaking based on the picture. The moisture on it, says so to me. Directly under that leaking elbow is the end seal of the lifter valley aka part of the LIM gasket set. The end seal is extremely unlikely to leak unless there is pressure in the crankcase. Pressure in the crankcase would typically blow out a valve cover gasket before the end seal. The dabs of RTV SG (SubwayGirl) is talking about form the gasket at the corner of the head to block, this is not a common area of leaking.
    Say someone left out the end seal or it fell inside during a LIM job, very little oil will splash around and seep out the space left from having no gasket in place. Jared... ask me how I know this. Jared, search on my name and "Eas y" w/o the space and figure out how it happened to me and how i know based on how I know about first and second design end seal gaskets.
    SubwayGirl is new to 3800's and learning fast, yet his is quite incorrect on his diagnosis of this leak. Sorry Jared, you are doing well with trying to help out, you don't have the years of experience yet.
  17. #17 Re: Oil Leak, What to do to fix?
    Jun 2015
    Wow, a lot of replies.
    Anyhow, I got grommets for the VC and aluminum coolant elbows already. So, once I get the VC and coolant elbows done I should be good? Of course clean all that up too... Thanks guys, especially Bill for all the great info!
  18. #18 Re: Oil Leak, What to do to fix?
    de grease it first, top and bottom of the engine. the day before or so, then have at it.
    di you also get v/c gaskets?
  19. #19 Re: Oil Leak, What to do to fix?
    Apr 2015
    Thanks Bill. I guess this was a big eye opener. I don't want to give people false advice or anything, I'm just doing my best to think of probable areas for this leak.
  20. #20 Re: Oil Leak, What to do to fix?
    Keep reading everything Jared, you are learning.
    Plus..as you read more and more, you catch guys like Scott and I going through stuff too fast and goofing up.
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
