Thread: coolant smell
Results 1 to 14 of 14
  1. #1 Re: coolant smell
    TDCRacing
    Guest
    cHECK AND MAKE SURE THE COOLANT OVERFLOW LINES ARE ON GOOD. Also check the actual radiator. New parts somtimes go bad and are not made correctly.
    Usually when they go bad it is on the ends where they weld the tanks on. so look there first.
  2. #2 Re: coolant smell
    Jan 2009
    Paducah Ky
    What he said above...sometimes the hoses need to be retightened. I would check them all, just in case. Also check around the water pump for signs of coolant. It could be coming out of the weep hole on the bottom of the pump. Not likely the way you describe it but still a good idea to check.
  3. #3 Re: coolant smell
    SE Level Member jersey jok3r's Avatar
    Northern New Jersey
    I have the same exact problem on mine but its coming from the driver side without smoke though. I just did a bunch of mods to my engine so maybe I didn't reattach a hose tight enough or would it be a different story because its on the other side of the engine?
    Ported Outlet/Inlet,3.4 pulley,ZZP PLOG, ZZP 3"DP,U bend delete, K&N CAI, ZZP wires,high-flow CAT, ZZP TB Spacer, Autolite iridium 104s,180tstat, OVERKILL PCM, Borla Cat Back system, Black Halo HIDS, Phantom autometer gauges
  4. #4 Re: coolant smell
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    Wow what an old thread dude. lol. But check where ur thermotat housing is. Did u bleed the system? might have a leak at the hose to the bottom on the PCM side.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  5. #5 Re: coolant smell
    Northern New Jersey
    I don't think its that, the car is not running hot at all and so far I don't think its leaking any anti freeze. I'm gonna let the car sit a little bit and see if it drips but I did just replace the pcm and the tstat but like I said the car is not running hot or leaking so far its just smells like anti freeze is burning on the driver side.
  6. #6 Re: coolant smell
    Are u positive its not leaking at the thermostat housing? Did u replace the o-ring and gasket it for it? u might not notice it as it could be slowly leaking under the LIM where it sits on top of the block. Take a little hand held mirror if u have one and look directly under the crossover.
    Let me know so i can help u as much as i can.
  1. Which coolant to use...
    By Rickochet in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2009, 08:34 PM
  2. Burning Oil Smell
    By Bruty74 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2008, 01:07 PM
  3. fuel vapor smell....
    By Vegas~Blown in forum General Tech Discussion
    Last Post: 09-01-2008, 10:45 PM
  4. Air condition/vents smell when turned on! How do I fix?
    By Freebeer187 in forum General Tech Discussion
    Last Post: 08-08-2008, 12:54 PM
  5. 2000 GP SE rich fuel smell out of vents this morning.
    By StreetChariot in forum General Tech Discussion
    Last Post: 04-29-2008, 08:54 AM
