MY LS1 TB pictures:
How it sits stock:
The press fit bond was ground off the shaft. now your free to remove the CRUISE control cable bracket, and the throttle cable bracket.
Reinstall them, "flipped" which is needed for both GenIII and GenV M90 set ups regardless if the TB is sitting vertical, (for the GenIII's) or flipped/inverted (for the GenV's).
Now make your best attempt at welding them back on/together onto the shaft they sit on.
I suck at welding, but its still holding strong, so who cares ya know.
Install:
This was my custom made GenIII billet aluminum plate, and the first ever and only one ever made, billet cable hanger was on this one. (which was sold to a good friendwhen I went GenV)
I'll see if I can find some pictures of my GenV LS1 pictures.
~F~
Took me a little bit, but finally found them.
Figured while everything if off the top of the motor, I might see about finally polishing my own TB, and MAF on up.
~F~
