Thread: At wits end. What is going on here..
Results 1 to 17 of 17
  1. #1 At wits end. What is going on here..
    memphis
    have a 2000 regal gs that has a rough surging, bogging idle when I first start it. It's bad enough it will die if it is in drive. I can rev it to 1200 rpm for a minute or so and then it settles down into a decent idle like there was never a issue.
    Runs fine after that. If I kill it, it will do it again hot or cold. I can then rev it to 1200rpm for a minute and then it is fine again. It makes a huge sucking sound while it isbogging and surging. Huge sucking sound goes away once it gets to holding a steady rpm.
    I have tried several mafs off running cars they all do the same thing.
    Engine was replaced with a low Mile unit and has ran great since it was put in. A case learn was supposedly not done when they did this. It seemed to run fine since the swap. And these symptoms don'think seem to be case learn symptoms do they? It is not showing any codes. I have checked for vacuum leaks but do not see anything Or hear anything when sprayed around with carb spray
    Any suggestions?
  2. #2 Re: At wits end. What is going on here..
    Sep 2014
    Worcester, MA
    I'd be looking for vacuum leaks.
    Any error codes? How is your MPG? Engine temp?
  3. #3 Re: At wits end. What is going on here..
    IAC could be a issue aswell.
  4. #4 Re: At wits end. What is going on here..
    memphis
    I Sprayed around with carb cleaner but it never had any effect. It throws no codes even when it is chugging and puffing down to 300 rpm. Sounds like it has a huge cam.
    Engine temp is fine once it evens out and I can actually drive it.
  5. #5 Re: At wits end. What is going on here..
    memphis
    Changed idle air control valve tonight with a new one I had. And put new o rings on the injectors. Neither of those helped.
  6. #6 Re: At wits end. What is going on here..
    Oct 2014
    portland oregon
    did you make sure the new iac pin was out the same as the old one? as i understand it that can cause it to not work right
  7. #7 Re: At wits end. What is going on here..
    memphis
    Yeah its the same . Even tried a known working one from a a friends Park Av before I bought the new one.
  8. #8 Re: At wits end. What is going on here..
    Bastard Reptile's Avatar
    Kansas City, MO
    Tried unplugging the MAF?
  9. #9 Re: At wits end. What is going on here..
    memphis
    Yeah it doesn't change anything. I swapped it out with the one from the same friends Park ave ultra as well. Same rough idle until I raise the rpms for a little bit then it is ok.
  10. #10 Re: At wits end. What is going on here..
    GTP Level Member
    Jan 2015
    Lincoln, NE
    I you let it idle long enough after the raising the idle dies it stay smooth or does the issue come back? Will autoparts store handheld show you ltft?
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  11. #11 Re: At wits end. What is going on here..
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Unplugging front 02 sensor make any difference?
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  12. #12 Re: At wits end. What is going on here..
    memphis
    When i Start it it runs ok for maybe half a minute. then it goes into the Bogging and surging. Like a rump rump rump... I Counteract it by raising the idle to 1200 or so for a minute and then i can let off the gas and it settles back to normal idle like nothing ever happened. I Can drive it with no issues then. If i Shut it off for say a hour i Have to go through it all over again.
    Sorry had to type all that out holding my 2 year old.
  13. #13 Re: At wits end. What is going on here..
    memphis
    Quote Originally Posted by 99GT2dr View Post
    Nope, does the same thing.
  14. #14 Re: At wits end. What is going on here..
    Cibolo, TX
    Couple other easy/cheap things I'd recommend is pulling/cleaning the TB ($3 gasket) and checking the pcv valve. I've heard the egr can cause similar issues, but I always ditch mine so I don't have any first hand experience with one going bad.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  15. #15 Re: At wits end. What is going on here..
    memphis
    It has the egr delete done on it and has run fine without it. Ill pull the tb and clean it. It's pretty clean though.
  16. #16 Re: At wits end. What is going on here..
    Kansas City, MO
    Other than actually hooking a tuner up to it, I got nothing.
    The start/running for half a minute thing says that it runs fine until it goes into closed loop.
    So, yeah.
  17. #17 Re: At wits end. What is going on here..
    GTP Level Member
    Jan 2015
    Lincoln, NE
    yeah but when he un plugs the up stream O2 that should also put it in open loop and it still does stupid **** then too...
  1. Running hot and at wits end
    By johnj4654 in forum General Tech Discussion
    Last Post: 08-06-2014, 05:09 PM
  2. At wits end
    By jrsteinbronn in forum General Tech Discussion
    Last Post: 08-02-2012, 08:57 PM
  3. At wits end... Security problem?
    By Carlos773 in forum Audio, Security & Visual Electronics
    Last Post: 04-01-2012, 10:28 PM
  4. At Wits End (97 GP GT)
    By ThaYeti in forum General Tech Discussion
    Last Post: 08-26-2011, 09:17 PM
