Thread: Tube between the air filter and intake manifold?
Results 1 to 20 of 26
  1. #1 Tube between the air filter and intake manifold?
    Mar 2014
    WI
    Does anyone know what this is called exactly? And where a replacement can be purchased? Thanks!
    Tube between the air filter and intake manifold? Attached Images
  2. #2 Re: Tube between the air filter and intake manifold?
    I have found many priced very good at my local junkyard.
  3. #3 Re: Tube between the air filter and intake manifold?
    i just gave my last one of them away, to that guy up there lol ^^^^^
  4. #4 Re: Tube between the air filter and intake manifold?
    Apr 2015
    Columbus, OH
    If only they made some tape for that duct. Dats what I'd do. Or just turn up the radio...right bill?
    Top Swapped 01 Imp
  5. #5 Re: Tube between the air filter and intake manifold?
    good time for a open cone filter
  6. #6 Re: Tube between the air filter and intake manifold?
    St. Louis
    Maybe try some foil tape. Should resist the heat and stay in place. Never tried it in an engine compartment before though. It'll allow you to get it into the accordion area and will hold it's shape.
  7. #7 Re: Tube between the air filter and intake manifold?
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Just get from a JY. If you really want I can get one for you, maybe. I'd have to check if the 7th generation GP's still have the intake tube. Unless a '97-'03 works too?
  8. #8 Re: Tube between the air filter and intake manifold?
    Mar 2015
    USA
    Junkyard. Mine did the same thing one day when I unhooked the dogbones to rock the engine.
    -'04 Impala SS - 3.6 pulley, AL 104s, ZZP DP, PLOG, 180stat, 1.9 rockers, gutted airbox mod, basic tune
  9. #9 Re: Tube between the air filter and intake manifold?
    97/98 tube is year specific.
    Same with 99-03.
    They won't work with the 04+.
  10. #10 Re: Tube between the air filter and intake manifold?
    Mar 2014
    WI
    For future reference, if anyone is looking for the specific part number, it's 15219032. Got it from gmpartsdirect.com.
  11. #11 Re: Tube between the air filter and intake manifold?
    Did you really spend $80~ on that thing? lol
  12. #12 Re: Tube between the air filter and intake manifold?
    Mar 2014
    WI
    No one else offered a specific place to get one cheaper.
  13. #13 Re: Tube between the air filter and intake manifold?
    I would have got a $5~ correctly sized coupler from Home Depot (like 2 3/4" or 3")...and install the grommet from the intake tube.
  14. #14 Re: Tube between the air filter and intake manifold?
    Apr 2015
    Quote Originally Posted by blueguy View Post
    Same with 99-03.
    I hate how the air box is set up in the '97-'98. The set up is much more reasonable in my car.
  15. #15 Re: Tube between the air filter and intake manifold?
    There is a solid 5~WHP gain from a 99+ airbox to the 97/98 guys...probably a smidge more so with a high flow filter in there, too.
  16. #16 Re: Tube between the air filter and intake manifold?
    Apr 2015
    Why would you make an air box where the tube goes out, then up, takes another turn and into the engine. Just stupid.
  17. #17 Re: Tube between the air filter and intake manifold?
    Quote Originally Posted by SubwayGuy View Post
    Because: GM
  18. #18 Re: Tube between the air filter and intake manifold?
    Enfield, CT
    Too keep the sound down.
    BTW. Car-part.com is great for parts
    Sent from my LG G3
  19. #19 Re: Tube between the air filter and intake manifold?
    Apr 2015
    Because: GM
    Just like how GM thinks it's a good idea to not put a drain plug on the tranny pan, use DEX-COOL, use plastic intakes, etc, etc, etc.
  20. #20 Re: Tube between the air filter and intake manifold?
    FWIW Dexcool doesn't cause the intake gasket issues. It's only true claim to fame is potentially turning to oatmeal if air is introduced. Ford, Chrysler and GM all went nylon based (plastic) gaskets around the same time and all of them had the same issues.
    My GM truk had a trans drain plug. Maybe it's just the cheap GP that didn't have one.
  1. Corroded LIM Lower intake manifold Get new manifold or is this one ok
    By jj5428 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-16-2015, 07:04 AM
  2. Replies: 12
    Last Post: 09-04-2014, 05:24 PM
  3. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  4. EGR Tube to exhaust manifold
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 02:43 PM
