I am looking to go the XP cam, S2 IC setup with my 05' GTP relatively soon here, and will be going with 60lb injectors. My question is at what point will I need to upgrade the fuel pump, or should this just be a upgrade I do at the same time?
Do a fuel pump rewire like a racetronix or Casper not a ZZP and I'm sure you'll be fine but of course you'll have to see if your maxing the pump out once you have your setup complete.
It's not E85.
It'll be fine.
