Thread: fuel pump upgrade
Results 1 to 20 of 26
  1. #1 fuel pump upgrade
    May 2012
    Where winter never ends
    I have an 04 gtp running e85, xp cam, headers, 60# injectors, full stack ic, and I desperatly need to upgrade my fuel pump. Which pump should I choose? The zzp one, aem, walbro? Which ones fit the best and will keep up with a 2.8 or smaller:-)
  2. #2 Re: fuel pump upgrade
    Max Cook
    Guest
    Dont get the ZZP one. I went through 2 of them in like a month trying to resolve a fueling issue. I switched to their new AEM pump and it works great. Way better. It supposivly is made to work with E85 too so I highly reccommend it.
  3. #3 Re: fuel pump upgrade
    May 2008
    Schuyler, NE
    I would go with a Walbro.
  4. #4 Re: fuel pump upgrade
    Portland Oregon
    Pm Tengis. He has great pumps at great prices.
  5. #5 Re: fuel pump upgrade
    May 2012
    According to intense's website walbro won't fit
  6. #6 Re: fuel pump upgrade
    May 2008
    Schuyler, NE
    Why not?
  7. #7 Re: fuel pump upgrade
    May 2012
    just isnt listen on the fit page?
    • 2001-2003 Bonneville with 3800 Series II engine
    • 2001-2002 Camaro with 3800 Series II engine
    • 2001-2002 Firebird with 3800 Series II engine
    • 2001-2003 Grand Prix with 3800 Series II engine
    • 2001-2004 Impala with 3800 Series II engine
    • 2001-2003 LeSabre with 3800 Series II engine
    • 2001-2003 Monte Carlo with 3800 Series II engine
    • 2001-2003 Park Avenue with 3800 Series II engine
    • 2001-2003 Regal with 3800 Series II engine
    • 2001-2003 other applications with 3800 Series II engine that does not use the venturi system. "
  8. #8 Re: fuel pump upgrade
    May 2008
    Schuyler, NE
    Quote Originally Posted by Adecker View Post
    They don't list it, since 04+ have returnless fuel systems. But, it still works.
  9. #9 Re: fuel pump upgrade
    May 2012
    What modifications are required?
  10. #10 Re: fuel pump upgrade
    Max Cook
    Guest
    You dont need the venturi system. You just need a different cannister or drill your cannister to run a pump that doesnt have a venturi. Thats what I had to do. I dont know much about 04+ though so im not sure if theres something else weird in their fuel system.
  11. #11 Re: fuel pump upgrade
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    message Paul at PRJPerformance.com. He is the man.
  12. #12 Re: fuel pump upgrade
    May 2008
    Schuyler, NE
    I could be wrong, but I don't think Paul carries a non-venturi pump. It would be worth a check though...he will bend over backwards to help you.
    You shouldn't really need any modifications, besides a pump rewire.
  13. #13 Re: fuel pump upgrade
    Donating Users Tengis's Avatar
    Houston
    There are no direct replacement 255lph pumps for non-venturi canisters which is why everyone recommends switching to venturi.
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  14. #14 Re: fuel pump upgrade
    May 2012
    Albuquerque, NM
    How do I look up of I'm Venturi or not?
  15. #15 Re: fuel pump upgrade
    Ohio
    What do you drive.
  16. #16 Re: fuel pump upgrade
    May 2012
    Albuquerque, NM
    Quote Originally Posted by MoarkatsINmuhtrailer View Post
    What do you drive.
    I drive an 03' Impala.
  17. #17 Re: fuel pump upgrade
    Houston
    You have the returnless fuel system. Venturi canisters only come in the previous gen Grand Prixs. Ive honestly always kind of felt that using a 97-03 fuel rail and adding a return line is the best option for 04+. You can easily do this for under $35 with a local trip to a junk yard. Ive bought the fuel line and fuel rails in the past super cheap.
    Question: is your fueling issue related to pressure dropping off up top? Having a pump that flows more fuel in your returnless system will keep pressure from tapering off but if the issue is your injectors then you would still need to upgrade your injectors.
    Satin Purple 97 GTP
  18. #18 Re: fuel pump upgrade
    May 2012
    The issue is pressure falling off as i get up past 6200rpm.
  19. #19 Re: fuel pump upgrade
    I wish someone out there actually documented a 2004 conversion. I have no patience for attempting a mod, finding out I need more parts (ie; ordering and waiting forever for it to arrive out of the U.S.) to find out I need something else as well.
    I need a grocery list so I can "get 'er done".
  20. #20 Re: fuel pump upgrade
    SE Level Member GrandPrixGT300's Avatar
    Sandusky, OH
    Any update on a pump that works for the 04+ returnless system?
    Andy
    99 GT (Stock - DD) & 04 Comp G (A Few Mods)
  1. Fuel Pump Resistor Upgrade
    By scootcoupe91 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2019, 01:31 AM
  2. 97 GTP fuel pump woes: Rewire stock pump?
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2013, 06:29 PM
  3. upgrade fuel pump no start
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2013, 01:24 PM
  4. 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    By corvettemike in forum General Tech Discussion
    Last Post: 04-07-2012, 10:04 AM
  5. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
