Thread: Wont idle without gas being pressed.
Results 1 to 12 of 12
  1. #1 Wont idle without gas being pressed.
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    Car: 1999 GTP: L26 top swap w/ Gen v on a stock pulley and a custom cam headers and a few other things.
    I recently swapped cams and loaded a base tune and it would idle fine, just a bit noisy because i didn't tighten the rocker bolts down enough. It also started first try and didnt smoke. Then i thought, while ive got the engine partially apart again why not gen v swap. Now she refuses to stay running without the help of my foot. It cranks and tries to fire once out of every 6-7 times. I also may have screwed up my starter because now all i hear is a whirring noise when i press the start button. She also smoked a bit, like a light whitish smoke when i did have it running.
    Edit:I did notice the gen v case is insanely close to the alt power bolt which may be causing issues. Im at work right now so scanning wont happen until late tonight early tomorrow.
    Id like to get it running right so i can accept a friend's race challenge.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: Wont idle without gas being pressed.
    Apr 2014
    South Haven, MI
    I may also need a vac line diagram from a gen v swap.
  3. #3 Re: Wont idle without gas being pressed.
    Feb 2013
    Missouri
    Everything is the same except for the PCV, it gets routed to the throttle body(that you drilled\tapped) or adapter plate (if it has PCV provisions). I personally used the Gen V evap solenoid with no problems, but I've read you can just cover the Gen V evap hole and use the factory solenoid\vacuum line if you wanted.
  4. #4 Re: Wont idle without gas being pressed.
    Apr 2014
    South Haven, MI
    I was messing with it yesterday and noticed that there was gas in the oil. Any ideas as to how that is happening?
  5. #5 Re: Wont idle without gas being pressed.
    Feb 2013
    Missouri
    stuck injector? all cylinders firing?
  6. #6 Re: Wont idle without gas being pressed.
    Apr 2014
    South Haven, MI
    Maybe i set the torque wrench too high and over tightened the rocker bolts?
  7. #7 Re: Wont idle without gas being pressed.
    Feb 2013
    Missouri
    You'd have to REALLY over tighten them to do anything like that, and even then something would break. Check fuel pressure with KOEO and see if it drops.
  8. #8 Re: Wont idle without gas being pressed.
    Rocker bolts would snap first.
    Which TB are you using?
  9. #9 Re: Wont idle without gas being pressed.
    Feb 2013
    Missouri
    ^^^That's what I thought, either that or strip the heads. I heard those PRJ rocker bolts are supposedly really strong.
  10. #10 Re: Wont idle without gas being pressed.
    Apr 2014
    South Haven, MI
    Im using an l67 throttle body
  11. #11 Re: Wont idle without gas being pressed.
    How are you applying vacuum to the pcv and what did you do with evap?
  12. #12 Re: Wont idle without gas being pressed.
    Apr 2014
    South Haven, MI
    Ive got a small breather attached to the nipple on the gen v. The evap is blocked off.
  1. Car wont idle?
    By thegipper in forum General Tech Discussion
    Last Post: 11-28-2011, 11:47 PM
  2. car wont idle. have to keep it running
    By jj7ski in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-21-2010, 09:20 PM
  3. wont idle down
    By tedrowkj in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2010, 10:04 PM
  4. wont idle
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2009, 07:40 PM
  5. Car wont idle help!!!!!!!!
    By GINOSGTP in forum General Tech Discussion
    Last Post: 05-10-2009, 06:30 AM
