Everything is the same except for the PCV, it gets routed to the throttle body(that you drilled\tapped) or adapter plate (if it has PCV provisions). I personally used the Gen V evap solenoid with no problems, but I've read you can just cover the Gen V evap hole and use the factory solenoid\vacuum line if you wanted.
